Results 1 to 20 of 20
    Apr 2012
    Hello, hingi lang po ako ng advise and help. I noticed that my rear wheel wears uneven mas nauunang nauubos yung loob na part ng gulong kesa sa kabila. Kia Rio po yung oto ko at 2 years na sya 29000 na po yung mileage ng kotse. Anyone has the same experience? Please share naman po kung pano na ayos. Thanks.
    Quote Originally Posted by jon_espiritu View Post
    back to CASA for free alignment or camber if it is still under warranty. if not, go to the nearest servitek they will be happy to assists you.
    Quote Originally Posted by brainmafia_310 View Post
    Rotate your tires after wheel alignment.
    Oct 2011
    check also tyre pressure.
    Sep 2009
    Stop patronizing Hella Flush.
    Check your wheel alignments and always the tire pressure. First time having a car? Be OC, treat it like your mistress (if already have a wife) or a GF. Rotate your tires every now and then.
    Jan 2009
    Most likely a toe misalignment. If the wear is on the inner tread, naka toe-out masyado (negative toe).
    In the off chance that there's no adjustment for toe in the rear axles, check suspension bushings and hub bearing for play.
    Quote Originally Posted by wezz_zzew View Post
    seriously? di pa din ba nawawala ang fad na yon? i just don't get why people deliberately destroy their perfectly good car.
    Jul 2012
    Pa-align mo lang yan tsaka pa-rotate mo na rin tires. Wag sa zafra lol
    o.t.
    Usong-uso pa rin to
    https://www.facebook.com/StanceNation
    Dec 2009
    Same case sa ngayri sakin pero sa front tires. Nagtataka lang ako alaga naman sa alignment ever 10k km and laging 35psi kahit 26 lang ang required.
    Jan 2008
    Quote Originally Posted by radz15 View Post
    Try mo kaya nag 26psi kasi yun naman pala required eh. Pag nag pa align make sure na 3d alignment machine ang gamit at hindi yung laser type na wonder
    Dec 2009
    Nag aalangan ako kasi parang flat sya tignan. Pero ayon kay servitek based na pudpod na nakita nya under flated daw yung gulong. San ba may 3d alignment sir? Karamihan kasi laser type
Uneven wear on my rear tires.
