Results 1 to 5 of 5
    hi guys just want to ask. My steering wheel for corolla xe 97 is uneven when driving in a straight path my Steering wheel is not even centered (medyo kabig sa right side) what's the problem? i had my power steering/rack end pinion kit repaired with alignment taps naging ganun... I checked with cruven they said steering clamp bushing dw any advice? what parts should i check thanks
    Feb 2009
    Quote Originally Posted by buboydc View Post
    first, replace steering gear insulators (bushings) to insure the steering gear does not shift either ways sideway.
    second, adjust your over-center adjustment (12:00 o'clock) position
    Aug 2006
    madali lang po ba palitan to? simpleng mekaniko kaya nito?
    or sa mga may pangalan ng shop po?
    magkano po yung ganung bushing?
    TIA
    Oct 2009
    [SIZE=3]puwede rin problem ang steering clamp bushings... check also the "wear & tear" of your tires... uneven na upod ng tires results in "off-center" steering... [/SIZE]
    Quote Originally Posted by ExROLLA View Post
    ok thanks for the reply. ayon din ung sabi sa cruven eh! sayang ung tires ko sa harap bago pa naman un. thanks for the advice
Uneven Steering PRoblem
