Results 1 to 10 of 10
    peeps need some help,recently napansin ko when im accelerating,may naririnig ako na ummugong na tunog.hirap explain pero umuugong talaga bumibilis din yung tunog nya pag bumibilis takbo ko,kala ko nung una may nakatusok na pako or sumasayad yung gulong sa fender o kaha ng oto pero hindi eh..basta ugong siya na very close sa tunog ng eroplano pag nagtatakeoff o naglalanding haha what could be the problem
    all inputs will be greatly appreciated.thanks
    malamang wheel bearing yan,
    what your car? Pwede bang pictures? do you have carrier? Fender sa harap? sa likod? where does the ingay come from? kana? kaliwa? Ilalim? harapan? Dami kong tanong no? agree ako k raine. Lets pinpoin the sound source para acurate...
    Quote Originally Posted by Kratos4age View Post
    Ugong can be your new tires...
    Or differentials...
    Dec 2004
    I had that same problem for a very long time.
    Kala ko normal lang yun for old cars. I thought it was the sound of friction between the tires and and the road.
    I recently had my transmission repaired, and when the mechanics test-drove my car, they heard the "ugong" and advised me that the wheel bearings were already very worn-out. Thinking that they are only after my money, I seek for second opinion. They other mechanic concluded the same.
    And so, I had the wheel bearings replaced. Tahimik na ngayon yung takbo, after 6 years of owning the car.
    Can't guarantee that you are experiencing the same problem though.
    tingin ko wheel bearing din ito..tagal ko na suspetsa ito eh
    wheel bearing yan... pang 4th time ko na nagpalit, same spot front passenger side, ewan ko ba at bakit ganun, palitin talaga... ganyan palagi akin, kaya pag medyo naramdaman ko na, palit na agad, kasi may one time hinayaan ko muna kasi wlang budget ayun napagastos ako, kasi nasira yung hub napudpod dahil wala nang bearing to support it, eh wala naman nabibili na hub lang, surplus lang ang binebenta sa banawe yung spindle, so yun ang binili ko, tapos nilipat na lang yung hub nung spindle.. napalaki pa tuloy ako ng gastos aruy ko po
    Up lang mga chief (instead of creating a new thread).
    Same issue with TS, and nagpalit na ako ng wheel bearings. So far, di na lumalakas yung ugong pag bumibilis ang takbo, actually wala na nga pag pabilis ang andar... pero pag pabagal na (aka tapak na sa preno), nagkakaroon pero medyo mahina.
    Curious lang kung possible bang defective ang nabili kong wheel bearings? Or possible na mounting ng goma sa mags?
    Na-curious ako kasi naalala ko naflat yung isa kong goma (na nasa passenger side-harap naka-mount). May bumaon kasing susi. Ngayon hindi ako nagpalit ng spare. Ginamit ko yung tire inflator ko (yung kinakabit sa cigarette plug na 300psi air compressor) para mahanginan yung goma. Totally wala ng hangin nung hinanginan ko. Ngayon, nabalik ko naman to 30 psi and nabyahe ko hanggang sa makahanap ng vulcanizing. Nung na-vulcanize (provincial trip), pasak lang ginamit (aka tusok)... and it's actually a concern ever since kasi alam ko di talaga adviseable 'tong pasak. Possible kaya na ito ang nagko-cause ng ugong ko pag pabagal na yung sasakyan? And if ever ano kaya pwedeng gawin? Patanggal muna yung goma sa mags, cold patch, then re-mount?
    May 2009
    have the same problem with my crosswind but a bit different...yun sa akin kapag liliko ako ng kaliwa at speed of 30kph above may naririnig ako unsual sound kapag kanan naman ang turn ko wala yung sound na yun it sounds like parang nag engine brake ka from let say from 5th gear to 3rd gear parang ganun...what I did is interchanged my front tires pero no effect..next thing i will do is the rear tire..btw my tire is asymetrical ba yun yung wlang baligtad (yokohama s306) and also nga pala meron din from sudden braking at high speed to slow down...ano kaya ito..need your input guys...thanks...
    Jun 2007
    how old is the tire? maybe it's already dead (oblong due to a broken steel belt). it needs to retire already if that's the case.
"umuugong" while running
