Results 1 to 10 of 12
July 9th, 2007 09:32 AM #1
tuwing nauulanan yung auto nag tutubig yung lalagyan ng spare tire sa trunk pati yung ilalim nung rear na passenger seat..san kaya galing to? my naka experienced na ba ng ganito?..TIA
July 9th, 2007 10:49 AM #2
July 9th, 2007 01:04 PM #3
additional questions lang sa yo bro.
pag basa ba yung lalagyan ng spare tire, basa din yung carpet sa trunk?
it is possible kasi that na may butas yung mismong ilalim ng oto mo, in which, water is collected lang sa may spare wheel compartment dahil ito yung pinakamalalim na part ng trunk eh.
kung basa din yung carpet sa trunk, possible na sira or worn out na yung mga rubber lining.
July 9th, 2007 01:06 PM #4
Check around the rubber seal around the trunk and trunk-lid. Sometimes it gets deformed or some sections have worked loose over time.
The same goes for the rubber seal around the rear doors.
This part might be a long shot, water might be coming up from the rear suspension mounts.
Zombie
- Aug 2006
- 728
July 9th, 2007 01:13 PM #5ganyan den ako dati. andami ko na ginawa, di ko talaga mahanap, so i ended up getting a hose at pumasok sa trunk at pina-sprayan ko ng tubig yung different areas. at yun, natuklasan ko kung san nanggagaling yung saken.
you can check on the water ducts ng trunk, depende kase sa vehicle eh, minsan may dugtungan (welding point) duon ng fender and ng body. ganun kase nangyari sa lancer ko.
nung pinalinis ko at pinapinturahan, nawala yung tubig.
- 299
July 9th, 2007 01:45 PM #6yung water sa sparetire lid ay malamang galing dun sa leak sa bubungan. dumadaan o gumagapang ang rain water sa kaha sa loob. makikita mo pag ni-remove mo yung panels. kung hindi mo pa mapapagawa tambakan mo na lang ng newspaper dahil tag-ulan na. mas easier magtanggal ng basang dyaryo kaysa maglimas gamit tabo, eh kung may makuha ka pang gurami. paktay na!
July 9th, 2007 06:27 PM #8
+1 to ghostrider. check the underside. my experience, butas yung 2 rear suspension mounts. gumagapang yung tubig to the lowest part which is well, the wheel well.
July 9th, 2007 06:39 PM #9
July 9th, 2007 06:45 PM #10
mahirap atang hanapin ang tuloy natin hehehe
ang daming pwedeng pag mulan.
try ko yung isang suggestion na papasok sa loob ng trunk at dun hanapin.
Eh ngayon BBM has just ordered the suspension of the fining of ebikes and calls for a grace period...
E-bike / E-trike ban details released by MMDA
