Results 1 to 8 of 8
- Nov 2006
- 201
December 4th, 2010 10:57 AM #1i hear that tsk tsk tsk when driving my 99 honda city type z sound especially on asphalted road. all tires are relatively thick about 90%. kinapa ko na isa-isa at di naman oblong. what could be the problem? wheel balanced last may 2010...
- Nov 2009
- 456
December 4th, 2010 12:07 PM #2Have your brakes checked, it may be dragging.
Are you sure the sound comes from the wheels and not from the engine compartment? It may be a loose fan belt.
- Jul 2003
- 573
December 4th, 2010 03:43 PM #3inspect all tyres. it could be an inside ply of the tyres that is damaged. Try to find and locate which of the tyre is causing this sound. Then have it removed
from the wheel to check the inside ply.
December 16th, 2010 10:36 PM #5
Wheel bearing noise is a continuous humming sound that goes faster and louder as the accelerates from about 40kph and abates as you slow down. Wheel balancing is if you're experiencing steering wheel wiggle at about 60kph and up and disappears at about 80 or 90kph.
Its probably the tires. Kahit na mukhang makapal pa, sometimes they cause that kind of noise. Now, if you're noticing the noise from the front and the car pulls to either side, the tire from the side where it pulls is defective. Steel belts inside are torn and separated causing it to bulge, pull to a side and become noisy. Delikado yan. It's the main reason for tire blow-ups.
Tsikot Member Rank 5
- Nov 2003
- 3,849
- Nov 2006
- 201
December 18th, 2010 11:52 AM #8id say it's more on tire defects. looks thick but probably invisibly oblong somewhere. though no problem with steering, no grabbing...
see my pahabol statement above. i mean, i can go on vacation anytime. but my spouse has her...
Traffic!
