80% of the time mag-isa lang ako nakasakay. pinaka madami ng nakasakay is 4 adults and 2 kids. ok na kaya kung gawin ko nalang 30/30 or 30/32?Originally Posted by Ungas
Signature
Guys, what are your tire pressures? I know there is a similar thread on this so I just want to get a survey and some opinions. My tires are BF Goodrich T/A 235/70R15. Current pressure is 27psi. So far ok ang ride pero someone adviced me on raising it up to 30psi cold. My exprience with that pressure setting before is that sobrang harsh ang ride ng Vit ko. Need your input guys.
Btw, I'll be installing a Safari snorkel this saturday. May old stock kasi sa shop ng cousin ko sa bacolod and he is selling it to me at a good price na installment basis pa. I'll be having it installed at RATS lang. P1000 labor charge daw nila.
If you want your tires to last stay with the 30 psi the safari is a very heavy vehicle and its weight will cause quicker tire wear on low tire pressures, remember a vitara weights far lighter than a patrol! :D I dont know if your tires are steel belted but if they are low tire pressures will cause severe mid term damage to your tires carcass, mmagkakaroon ng lumps and can blow up while you are running! Not a very safe situation 8O
since tire pressure na topic... makisingit na rin ako... ano ba dapat ang tire pressure ng 31x10.5 15 Radial All Terain BFGoodrich uses in a 3 door Pajero Mini, currently 28front tapos 27 likod ok lang ba yun? gamit ko is yung sa shell na digital air pressure.
nabasa ko sa magazine is to draw a line using chalk sa thread, kapag same yung wear ng chalk ok ang pressure, kung sa gitna, sobra, kung sa edges malambot,
btw my tire pressure is 30 psi no all four
yokohama geolandar AT2 + 31s
I read in another 4x4 forum they used 25 front and 20 rear for a gen 1 paj 3dr on MT tires 31x10.5. This was his everyday setting including highway use. This was after testing dif pressures ranging from 10 to 35. He used a lower setting though pag nag off-road.
Not sure about AT's though.
32psi cold on all four corners for my ride. Pag mainit na nasa 36psi.
wiretap_md::: Daanan mo lang ako dito pag wala kang kasama! :D
i use 31 x 12.5 m/t mikey tires <---hangin ko is 26 before is 22 tama ba?
AFAIK, 28 ata minimum pressure. Anything below is considered underinflated.
Thanks for the reply guys. Sige, I'll raise my pressure back to 30psi on all fours then observe again.
Ungas: Sa RIDE nalang ako papakabit on Saturday afternoon. P500 lang ang installation charge nila compared sa P1000 ng RATS. Yup, ako lang mag-isa. Sama ka?
Sure! I wanna see your face how it reacts when they start drilling holes on your fender, hehehe. :mrgreen:
Tawagan mo lang ako, on the way rin naman kung papuntang Banawe. :D
why mo nasabi towing specs? ano ba dapat ang tire pressure sa patrol?Originally Posted by pajerokid
Signature
boybi,
usually when towing mas mataas ang pressure nung sa likod. Sa pajero 40psi yung rear kapag may trailer.
wiretap_md,
ano papakabit mo sa fender?
pajerokid: Safari snorkel. My cousin offered it to me kasi installment basis so I grabbed the opportunity. Preparing for the Espana floods..hehehehe.
ah oki :D bagay na bagay yan sa Espana! Waist deep pa rin ba? Dati sinabak ko box type ko diyan, atras ako hehe
pajerokid, safe bang gawin 32psi yung likod? tapos retain ko 29psi sa harap?
Signature
