Page 2 of 2 FirstFirst 12
Results 21 to 34 of 34
    #21
    Originally posted by Gi
    trailing arm bushing nasa likod makikita sa trailing arm assembly, the assembly on the lower part of the suspension para syang malaking hinge and made of metal.
    wrecker,
    wat you mean pina "machine" ang bushings? pede pa repair yun?
    I think the better term would be "machine pressed".
    Jul 2003
    #22
    tagal na yung last post dito pero buhayin ko ng mga brus instead of making a new thread na ganito din ang topic.
    nagtanong tanong ako ng bushing para sa civic esi 93 at ito ang quote sa akin:
    trailing arm bushing - Php360 to 450 per piece
    compensator arm bushing - Php150 to 200 per piece (parang mahal ito kasi liit lang yun eh)
    upper arm bushing - Php200
    lahat yan replacement lang. reasonable ba presyo???
    ayaw ko pa sana papalitan kaso si misis naiirita dun sa squeaky sound lalo na pag long trip. ok lang ba kung spray ko muna ng silicone spray para mawala ang squeaks. tingin ko ok pa naman bushing kasi ndi naman nag sway ang likod ng kotse during braking even in high speed.
    #23
    Makikita mo naman sya kung sira na.. dahil sa may crack sya kung sira na.
    #24
    yung sa ek ko fabricated bushing din ang pinapalit ko 2 yrs ago, hanggang ngayon ok pa din mga 300pesos ata per side. sabi kasi yung OEM madali masira.
    Nov 2003
    #25
    problem with the fabricated or solid bushings is that ride quality suffers a lot.
    #26
    Yun sakin nga gusto ko ng palitan ulit. laging may langitngit, M7 ang gamit ko now sa kabilang side.
    Sep 2005
    #27
    me fabricated din from cruven. medyo stiff na yung ride but tollerable naman. 350 ata per side if i remember.
    Nov 2003
    #28
    langitngit is normal lang sa kanila pag solid.
    #29
    how do you diagnose bushing problems? have had my opel checked in 3 shops already for a rattling noise in the rear. pag inangat and inspect ok pa naman daw bushings, and they cant find anything wrong. but the noise is still there!
    sa bridgestone they even use a crowbar like thing to push the bushings against the chassis. is that a good test?
    Nov 2003
    #30
    if bushings are busted they normally have visible cracks.
    #31
    Quote Originally Posted by n5110 View Post
    di naman siguro madaling masira yung OEM. baka mali lang ang procedure ng
    pag kabit kaya yung iba bumibigay agad...
    #32
    Quote Originally Posted by manager View Post
    ok lang yun. sinisilip lang nila if my cracks na bushing mo.
    Jun 2007
    #33
    I tried using M7 bushing advantage matibay at mura, kailangan lang ipa wheel align pumapalo ung likod pag curve o paliko, na pansin ko lang may tug sound pag humps at ung kamot nang gulong di even
    Mar 2011
    #34
    1995 civic esi ang ride ko. ung bushing din ba ang cause ng squeeks na naririnig ko especially pag dumaan ako sa humps? kaso pag basa o umuulan nawawala ung squeek na naririnig ko sa suspension sa likod. or is it the shocks mismo and nag-squeek?
trailing arm bushing!
