Page 1 of 2 12 LastLast
Results 1 to 20 of 23
    Oct 2003
    What's the best thing to do in an unlikely event of losing brakes at high speed? If the car is loaded, will the parking brake's cable snap if I engage it?
    engine brake ka muna.
    you might lose control of the car if you yank the parking brake at speed i think...
    best thing to do would be to downshift to a low gear and let engine braking slow you down (don't blow the engine though hehe)... then hold on and pray :D if the road is wide open with no traffic, i suppose swerving hard left and right slalom-style would scrub some speed as well
    The Best thing you do is DON"T PANIC.... downshift to reduce the speed.. act fast and decide according to situations.. find the best scape route to avoid serious accident..
    If you lock your rear wheels, you will loose control of the car and would probably result in a spin-out.
    Use engine brake technique to reduce your speed low enough where you can apply the hand brake without loosing control.
    First would be to downshift a gear or two and let the engine brake.
    You can use the E-brake/parking brakes but dont just yank it hard. Pull it up slowly and hold it steadily without locking it (hold the lock button down).
    If its a big emergency like you'r driving on a downhill, mountain road, engine brake and try to pick something to hit/brush against to scrub off some speed. Just dont hit it directly.
    Of course, the most important thing is to preempt such an event by making sure your car is in good running condition with the help of regular maintainance and chek-ups.
    Mar 2003
    paano pala kung matic?:confused:
    Make sure first that the brakes have indeed failed. Most of the time, only the vacum assist fails that's why the pedals seems very stiff and there seems to be no braking effect. Use both feet to push the brake pedal down and put all your weight on the pedal.
    Assuming that the brakes have failed, shift to a lower gear (engine brake) be it manual or automatic. Then slowly engage the parking brake.
    Sorry, medyo ignorante ako sa mga terms, what is "engine brake"?
    operational definition: cruise at 3rd gear, then downshift to 2nd, keeping your foot off the accelerator. the car will lose speed as the revs jump.
    jump out of da car pag last resort na!. hehehehehe
    odell,
    nyek siguradong mas mamamatay ka pag gawin mo yun hehe
    deploy the parachutes at the back!!!
    pero seriously, engine brakes muna, tapos slowly apply handbrakes.
    Jan 1970
    OK kayang accessory na kabitan ng retro rockets yung car ??? For emergency braking of course.. :-)
    what if, shift to low gear then turn off the engine?
    will it work??
    pray hard!
    Masakit din pala sa paa ang pulse ng ABS, first time ko lang na XP ito along quezon ave. patawid ng araneta. I was doing 60, tapos two posts away bigla ba namang sumulpot yong mmda pa paparahin ako. Pero I did it after ensuring na walang sasakyan sa likod ko, at baka ma-rear-end naman ako.
    will it work??
    siguro it will stop pero most definitely bungi bungi yung gears.
    expect a transmission overhaul or replacement.
    engine brake...
    pag medyo mabagal na..
    parking brakes naman.
    kung ayaw talaga..
    if you need to hit something for you to stop..
    try hit a wall and not a post..
    mas ok impact noon..
    distributed.
    diba aandar din ulit yun kaagad kung patayin mo yung makina in gear? you'll probably wreck the engine and tranny though
Loss of Brake - What To Do
