Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    Sep 2008
    Hi Guys, need your advice here.
    My car is experiencing some weird sounds during braking. A "TOK" sound comes up during stop and go driving, this happens when i press the brake lightly. This does not happen at high speed braking or when i fully press the brakes
    Im driving an automatic by the way
    Hope to hear your advice!
    baka maluwag lang yung disk brake caliper.
    Nov 2006
    Quote Originally Posted by buchieboy View Post
    pakiramdaman mo kung saaan galing yung ingay kung sa harap o likod.
    Sep 2008
    Quote Originally Posted by dennis powell View Post
    Sa harap ung tunog Driver Side
    It also makes sounds when i release the brake (minsan lang)
    Sometimes may screetch sound din when braking coming from tha back (kung kakabukas lang ng kotse and it disappears after a few brakes)
    If its brake calyper, minor lang ba un?
    caliper or shocks
    Sep 2008
    I recently discovered another "TOK" sound.
    This happens when i step on the brake pedal and turn the steering wheel to the left it produces a single "tok sound" after that wala ng tunog maskin ikutin ko to the left while pressing on the brake. It only reproduces the sound when i let go and press the brake pedal again and do the same procedure.
    Ano kaya problem nito?
    kung minsan yung hub bearing assy mo ang cause
    to check ,hoist up the car and use a pry bar .
    pry it in between the steering knuckle and hub assy
    Sep 2008
    guys, thanks for all your advice.
    got it checked at toyota yestrerday, nilagyan lang nila ng lubricant then nawala na ung tunog!
    Thanks!
    bro ano ang nilagyan ny lubricant? yung pin sa brake caliper ba? kasi noong nagpatingin din ako para sa civic maluwag yung pin kaya lilagyan lang ng lubrican yun solved na.
    Mar 2007
    if its a single tok, i dont know
    but if its tok tok tok tick tick tick with pedal pulsations, then its the ABS. maybe you have a dirty wheel speed sensor. kaya nag aactivate ang abs,
"Tok" Sound when braking at low speeds (Yaris)
