Results 11 to 20 of 22
July 23rd, 2009 01:39 PM #11
July 23rd, 2009 01:49 PM #12
^Agree. If your mechanic is good, then he will also do a good check-up. Based on experience Cruven people are good, they are very meticulous in suspension check-ups. However, the repair will really depend on the condition of the existing part which means that there is no guarantee that the repair will last that long.
Rapide..they suck...
July 23rd, 2009 02:02 PM #13
Another RAPE DI car from Rapide...
* TS. Read other threads on Rapide's feedback here. Its for you to decide if you'll go to them or not.
If its ball joint or tie rod end, then it can be replaced as it is, not the entire assembly. Other parts na pupuwede makasama, is yung CV boots/joints
- Feb 2009
- 36
July 24th, 2009 03:42 AM #14my tie rod and rack end was replaced... pero nawala yung kabig at bawi nugn steering ko... i just had my tires replaced and was supposed to have wheel alignment and camber correction... pero di nagawa kasi mababa daw ng 1 inch yung front left side compared sa right side...
ang sabi sa akin e either rubber lifter or springs??
any suggestions? di ko muna ginamit yung oto ko.. baka madale yung mga gulong ko or baka maaksidente pa ako e... help please?
July 24th, 2009 07:31 AM #15
^naka lifter ka na ba bro? if you are currently using one, just have them replaced.
kung hindi ka naman naka lifter, yup, probably your springs are already soft. also have your shocks checked.
July 24th, 2009 08:00 AM #16
gumagawa din ng lifter (rubber) ang cruven. mababa din kasi yung left rear ng kotse ko dati. ok naman gawa nila. alam na nila ang diskarte. mga 500 ata nagastos ko. part (rubber) and labor na yan
cruven talaga.. value for money, may warranty pa. update mo kami.. mukang kailangan ko na rin magpa cruven ulet . bumabalk na ulit ang front kalampag ko after 3+ years.
July 24th, 2009 08:43 AM #17
Why did you have lifters installed in your nissan LEC? Did you intend to have it installed for a higher ride height?
You can try removing the lifters and reinstalling the springs without them. See if uneven pa rin ang ride height. If okay na, then the lifters are the culprit. ^_^
- Jul 2009
- 20
July 24th, 2009 10:22 PM #18Mga ka-tsikot, dinala ko kanina sa cruven car ko and maluwag na lock ng bearing and caliper lang yung source ng tok sound. 250 + 50 na pangmeryenda nung gumawa nagastos ko. Haaaay salamat sa cruven. Ok na ok service nila sobrang friendly ng mga tao dun. Babalik pa ako para sa mga shocks ko.
- Sep 2009
- 35
April 27th, 2011 10:27 PM #19up ko lang po ang thread ..
93 corolla kotse ko.
napalitan na mga bushings sa ilalim pero meron parin "'tok'' sound pag sa rough road... dinala ko ulit sa talyer and just found out na galeng pala sa rack and pinion ang sound kasi nawawala ang ''tok sound'' kapag hinahawakan ng mekabniko habang pinopokpok ang right front wheel. sira na raw ang bushings. canvass muna ako kung magkano. kapapalit ko lang kasi ng 3 wheel bearing (1 front and 2 rear). butas na ang bulsa ko..lols...
- Sep 2009
- 35
May 3rd, 2011 12:06 AM #20
I also prefer silver. hindi halata na madumi na and some imperfections like faded color and slight...
