Results 1 to 10 of 15
- Sep 2003
- 9
June 5th, 2005 06:56 PM #1Im sourcing for cheap but dependable tires, san ba mura bumili?
okay ba bumili ng tires sa blumentrit? saka meron bang shops who sell 2nd hand tires? just need help guys, baka may contact no. kayo.....
by the way 17" 205/40 ang hanap ko. thanks.
- Feb 2005
- 36
June 6th, 2005 11:02 AM #2Question lang po.... are second hand tires really dependable? especially with low profile tires? Regarding your question,
In banawe, there is a shop beside Banawe Car-care center which sells slight used 17" tires. They offered me a 90% kumho 215/45/R17 tires for only 3.5k each but I found a lot of 205/40/17 tires there also, not quite sure if they come in pairs. You could also try there. Goodluck!
June 6th, 2005 11:59 AM #3
i've never bought 2nd hand tires, so i can't comment on that point...
but as where to buy, 2 lang pinupuntahan ko, blumentritt and evangelista. from experience mas mura sa blumentritt ng konti
June 6th, 2005 12:02 PM #4
2nd hand tires are not a problem, just make sure the sidewall is not damaged in any way. thread wear should also be at least 60%. some hole patches are unavoidable basta the most important is the sidewall, dpat walang cracks etc
June 6th, 2005 12:07 PM #5
beware of 2nd hand tires.
inspect carefully if it has a crack (even minute ones) already. most people just check if the sidewall is intact.
June 6th, 2005 12:14 PM #6
yeah doble ingat when buying 2nd hand tires..baka kasi anong sira nyan ang hindi mo nakikita..if you got the money naman, then buy brand new ones na lang..
June 6th, 2005 12:46 PM #7
2nd hand tyres? Blumentritt at Evangelista ang the best. Like what the guys said, check for sidewall damage and look for cracks, like what mazda suggested. Cracks on the sidewall or dun sa tread eh tell-tale signs of aging. As far as the tread, try if you can check if the tread still has 2-3mm of the original tread depth remaining sa may center. Anything lower than than 2mm, forget it: it ain't safe.
Also, beware: some shops sell re-groove/re-tread tyres as new ones. Baka ma-dale ka.
- Feb 2005
- 36
June 6th, 2005 12:58 PM #8Yung turo ren pala sa akin ng roadstar. Carefully check the manufacturing date even when buying bnew tires. Like the tires I had. They were bought last March 2004 by the original owner but they gave him year 2000 manufactured tires so when 5 year rubber life came it just cracked up. it barely made 14mos.
June 6th, 2005 06:38 PM #9
sa blumentritt janus clinton hanapin mo si caloy or noel, dami parating na second hand japanese tires, and mags ,meron nga syang 20 "mags less than 35k ,wlang lang money too buy ehh sayang yun
June 6th, 2005 07:09 PM #10Originally Posted by madmaxmaloles
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
