Results 1 to 20 of 20
    I have 3 out of 5 tires for our Altis which seemingly have defects, but I need to know which two I can still use until I get my tires replaced.
    Here's the first tire, a Dunlop Sport 01 (205/55 R16), currently my spare tire. It was punctured twice on its sidewall, and it seems to have developed a bump:
    Here's the second tire, also a Dunlop Sport 01, which by the way are the stock tires the car came with. There's seemingly a tear on the sidewall:
    The third tire is new, less than a month old, a Dunlop LM703. Less than a week with the tire, it developed a large bump on the sidewall. More recently, the bump started developing tiny cracks:
    I'm going to try and get the LM703 replaced under warranty, as it's practically new. I doubt that the Sport 01's will get replaced as well though, what do you guys think? My guess is that Toyota will just say it's wear and tear. The car's 2 years old by the way, and has around 35000 km on the clock.
    Lastly, if I really do have to get all 3 tires replaced, what other brands do you suggest? I'm thinking of getting the tires not from the dealer anymore, as the pair of LM703's I recently got totaled over 12k, with wheel balancing included.
    I've heard that the Kumho Ecsta is rather decent, how much would those tires cost in 205/55 R16 form?
    Thanks guys.
    hindi kaya parati ka na-gutter?
    I'm not the only user of the car. My mother has had quite a few incidents of hitting the gutter, hence the vulcanized patch on the first tire. Personally I've never hit the tires on anything, except probably a few potholes I was unable to avoid.
    Consider the Yokohama A.Drives
    I've got a set as stock on our 09 FD, in your size (205/55/R16)
    Relatively quiet and the price shouldn't be so bad. (~3k ea)
    As to your original question, I wouldn't consider using those tires anymore. Punit and bump on the sidewall - no no.
    Padala mo nalang kaya yung rim mismo sa shop?
    If not, just drive sloooooooowly :O
    Quote Originally Posted by mda View Post
    where do you get you A.drives? thats cheaper than the 185/65/14 i canvassed.
    I was looking a the A.Drives as well. How does it perform in terms of its grip levels? I'm having this (unsubstantiated) notion that the A.Drives are generally budget tires, having only 3 grooves. This has got me to consider the C.Drive, just because its marketed by Yokohama as better than the A.Drive. I haven't looked at its price though, but if its at the 3.5-4k range but provides better grip and is more reliable, I'd give it a go.
    I'm concerned about the tires' performance because aside from city-cruising duties, I sometimes bring the car for a spirited drive at Tanay so I'd like the tires to be grippy and predictable, and during highway runs I want a tire that won't blow on me when running at around 150-200.
    I checked with DKC a few months back and 205/55R16 A-drives was around P4.9K already.
    Well, I really haven't taken the car above 100 for sustained periods of time, nor have I gone at 100kph in the wet, so I can't comment on the grip.
    With regards to the tire blowing on you, I'm pretty sure this will be down to the load/speed rating of the specific tire. I think the stock 91Vs will be good all the way to 200kph.
    Oh yeah, back to my original question, which of these tires are still safe to be used?
    Thanks guys.
    To answer your question: None
    On what to get, the A-Drives come as standard on the Civic with 16" tires and feedback is generally good.
    Jun 2010
    the A drives are pretty good. much better than any dunlop LM series. these came stock with the civic FD (1.8S) and ours are still pretty decent even after 4 years and over 40,000 KMs.
    the kumhos are okay as well, i think these are stock on the newer hyundais. haven't used them for a long time though (over a year old pa lang on our hyundai).
    Only good experience i had with dunlops are with the LeMans RV (RV501) way back in our old CRV. the LM (701, 702 and 703) all gave me headaches (experienced a sliding tail, pothole blowout, and numerous bubbles on the side walls)
    Jul 2006
    Where have you been driving?
    The A.Drives seem to have generally positive feedback. Any comments on the fact that it's locally-made? I've got a friend who has a Civic 1.8S, he opted for a set of Ecstas over A.Drives because he says that the locally-made A.Drives are more prone to blowouts. These are at about 5k a piece, yes?
    Also, how does the A.Drive compare to the Dunlop SP Sport 01?
    And, what about the A.Drive versus the Ecsta SPT?
    Personally, I just use it when strutting about the metro, as well as the occasional highway/provincial back-road run. The punctures were all incurred with my mother behind the wheel, mostly through hitting the gutter, such as in parking lots.
Which Tires Can I Still Use?
