Results 1 to 10 of 12
February 1st, 2007 12:27 PM #1
I bought 2 new rear tires 2 years ago. Strange only one tire (left wheel) wore off faster than the other one.
ANy inputs?
thanks guys
br,
city
February 1st, 2007 03:47 PM #3
saan part ng gulong un wear?
alignment prob nga yan.
pacheck mo including camber.
February 1st, 2007 05:54 PM #4
- Nov 2006
- 299
February 2nd, 2007 03:45 PM #5anong klaseng tire thread wear yan,,,,feathering,cupping,one side wear,centerline wear,outer tread rib or shoulder wear?
February 19th, 2007 07:26 PM #6
A related question...
My rear tires would wear faster on the inside since the Rav4's rear has a negative camber setting. The wear on the rear tires is quite noticeable if you forgot to rotate your tires (guilty!) every now and then.
To salvage the tires, what I did is to have them unmounted, flipped them (so that the outside is now in the inner side) and then mounted them again to the wheels.
Is that ok?
P.S.
My better tires (almost brand new) are in front and I am hesitant to move them back because of this.
February 19th, 2007 08:39 PM #8
another related question...
one of my front tire developed an unusual wear... about 4-in on the inner portion only has worn out (hindi naman natuklap), could it be a case of manufacturing defect? the 3 other tires don't have any problem, tinanong ko sa casa kung pwedeng palitan... di na raw kasama sa warranty
all tires are stock and 18 months old.
February 19th, 2007 09:22 PM #9
nangyari na din sa akin yung inner side ang mabilis nasisira ang may diperensya eh yung wheel bearing...
a quick way to find out if ur bearing is still ok...i jack mo yung side na mabilis masira yung gulong tapos i shake mo yung gulong pag maalog baka sira na yung bearing/hub
* sir mazda.. basta nde directional yung tire ok lang i swap yun
- Dec 2006
- 5
April 30th, 2007 02:26 PM #10magkano po ba magagastos sa wheel alignment?
eh kung kasama po camber alignment?
need po ba talaga na kapag nagpa-wheel alignment sabay ng camber alignment na rin?
at what instance do i need wheel alignment? camber alignment?
thanks.
