Results 1 to 8 of 8
    Good Day Mga Sir,
    I need help po with my car problem. everytime i turn right, whether it is slow or fast, i heard a loud noise with my tire scratching or rubbing on the road, parang tunog po ng gulong sa starting point ng carera. pero pag liko po ng left ok naman. i've brought my car sa tire alignment(digital or electronic na gamit nila), ok namn pati camber, tie rod, ball joint, new tires except yng right rear shock ko may konting tagas na.
    help namn mga sir if you experience this kind of problem at ano mga possible solutions.
    ang oto ko po corolla 93 xl big body, not power steering.
    salamat na marami.
    Jun 2006
    Malamang tunog ng slipping fan belt yung naririnig mo sir.
    Quote Originally Posted by MISFITS View Post
    Good Day Mga Sir,
    salamat na marami.
    What kind of sound is that exactly? Is the sound a squeaking sound, grinding similar to metal to metal contact, or something like a loose fanbelt kind of sound? However, by your description of when the sound occurs it seems like your wheel bearings made need to be repaired.
    Aug 2004
    check mo yung side wall sa gawing loob ng tire kung meron part na gasgas. baka may tinatamaan pag nag-right turn.
    salamat po sa mga input mga sir.
    i'm sure the sound is not a slipping fan belt, it is the tire. i already check the sidewall if there is any contact between my tire when turning right but i haven't found any.
    anyway, pa-check ko rin ulit yong belt ko kasi kakabit lang nito baka nag loose pati yong bearing ng water pump at compressor, pa check ko na rin baka ito yng may problem kasi maingay minsan ang belt pag naka aircon.
    i'l let you po pag ok na.
    again, salamat na marami
    get a second opinion from another shop. most likely something like this gulong mo -> | \ ganyan din dati sakin nung nagpalit ako shocks e.
    Quote Originally Posted by caloyski5
    gulong mo -> | \
    Aka ung isa naka turning angle.
    Sep 2005
    could be fender lining ang tumatama sa gulong mo while turning right? just a thought.
Tire Sound When Turning Right
