Results 1 to 9 of 9
    Guys, ano official metric equivalent ng 31" x 10.5" R15????
    a) 255/70R15
    b) 255/75R15
    c) 260/70R15
    d) 265/75R15
    e) 270/70R15
    f) 275/75R15
    hindi po quiz to hehehe :D i tried computing for it pero ang hirap ma-determine coz the resulting figures are so close.
    Mahirap yan. gagamitin ko pa utak ko. bukas na lang 10 o'clock na . GOODBYE :mrgreen:
    tama po si afrasay, 10 o'clock na, mahal ang overtime charge. :mrgreen:
    Signature
    Hmm... a tricky equation!
    Pag ang habol mo yung actual diameter ng tires:
    Sidewall_Radius_Diameter_Circumference_Metric Size
    7.4in_14.9in_29.9in_93.9in_270/70-15
    8.1in_15.6in_31.2in_98.1in_275/75-15
    ahehehehe :D Sir Alf talaga!
    anyways, heto ang ginawa ko.....
    * 1in = 2.54cm
    31" - 15"(wheel) = 16"; (total tire dia)
    16" / 2 = 8"; (sidewall length)
    8 * 2.54 = 20.32cm; (sidewall in cms)
    10.5" * 2.54 = 26.67cm (tread in cms)
    to get aspect ratio..........
    20.32 / 26.67 = 0.7619 (ANO BA ITO, 75 NA?)
    to get tread............
    *1cm = 10mm
    26.67cm * 10 = 266.7mm (MGA CHONG DITO AKO NALALABUAN)
    HELP!!!!!!! I just want to compute for my speedo's discrepancy since i upsized my wheels and tires. ty
    hehehe 10 na nga, uwi na rin ako!!!
    Pahabol out na rin ako...
    check this out pajerokid:
    http://www.sgmotorsports.com/tiresize.htm
    Baka makatulong sa pag compute mo ng actual speed.
    buti na am ko binasa ito
    the nearest possible answer is
    265/75/15
    dont ask why how and what?
    matagal ko nang compute yan nung naka 255/70/15 pa ako
    Bakit hindi mo na lang sukatin yung overall diameter using a tape measure? Madalas din namang inaccurate yung size sa side wall by 0.4"-1.0", eh.
    Otep, thats exactly the point. Hindi accurate yung "tale of the tape". Tire wear, load, air pressure, temperature and weight all play a factor in the diameter. i'd rather get the "official" size coz malamang ito ginamit ng manufacturer nung kinompyut nila yung ikot ng gulong para sa speedometer reading. :D
TIRE Q
