Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
    Jun 2012
    ^Ilipat mo yung suspect na gulong, pag lumipat ang tunog o nagbago ang tunog, possible na gulong. Pag bearing, nalalaman ng nag-aalign yan.
    Jan 2014
    mga sir, same problem encountered but mine is nag chug chug or parang dumadaan ka sa lubak pero naeencounter ko sya pag umaabot ng 2000 rpm pataas tas pag nag shift ako nawawala then babalik pag asa 2000 rpm na naman.. nagpalita na ako ng engine support pero meron pa din.. me nagsabi sa akin na wheel bearing yung iba naman camber allignment naman.. ano kaya problema??
    Quote Originally Posted by jocampo10 View Post
    Mine was usually associated with speed and the noise would occur when I hit 40kph or when I was turning. As I would speed up, the noise would also go faster until I reached 8kph from where the noise would be fast enough to be just a big droning hum.
    Jan 2014
    Quote Originally Posted by K.I.L.L. View Post
    ahh.. wala po bang vibration? yung parang nalulubak ka?
    There was vibration which can be strongly felt on the steering wheel. The vibrations were synchronised to the thumping noise so it was associated with the wheels.
    Sep 2009
    GD pre. I'm one of those unlucky IDSI owner na nakabili ng lemon.
    Sent from my iPad using Tsikot Forums
    Sep 2009
    Honda city GD. May possibility na oblong or may mga lumps na gulong mo pero pacheck mo din wheel bearing sa trusted mechanic mo para sure. Kung lumalakas yung tunog habang bumibilis ka, then, parehas nga tayo ng naging problema.
TIRE NOISE DURING ACCELERATION - Chug, Chug, Chug
