Results 11 to 20 of 27
    Sep 2009
    Nung pinacheck ko sa mekaniko ang sabi nya may problema daw yung gulong kaya ni rotate namin lahat pa X. Nung tinest drive, andun pa din yung tunog. Pag wheel bearing ba chug,chug ang tunog? Hindi ba parang whirring sound? Kakapalit lang ng suspension at stabilizer.
    Sent from my iPad using Tsikot Forums
    Jul 2011
    Ano manufacturing date ng gulong mo? Kahit makapal pa yan pero more than 3 years maingay na yan pag umiikot sa daan.
    Sep 2009
    I'm not sure kung sa gulong ko ang may problema dahil narotate ko na pero nandun pa din yung noise. My two front tires are both Westlake (bought it 6 mos. ago) while Bridgestone naman sa likod. I'll have it checked na lang on saturday. Sabi din nga pala ng mekaniko, damaged na bushing ng rack and pinion ko. If ever, baka pa check ko na lang yun pati wheel bearings. I'll update everyone na lang pag naayos na. Thanks!
    Quote Originally Posted by wezz_zzew View Post
    is it possible, all your tires are out of round?
    over-inflation is a popular way of getting premature tire failure (out of round).
    Sep 2009
    Inform ko lang po everybody na ok na ung issue. The culprit, wheel bearing on the right side.
    Damages:
    Wheel bearing - 1k
    Pressing - 250
    Labor - 250
    Tip - 50
    Happiness - Priceless
    Damages:
    Wheel bearing - 1k
    Pressing - 250
    Labor - 250
    Tip - 50
    I knew it. I'm glad you got it fixed man.
    Jan 2014
    mga sir, same problem encountered but mine is nag chug chug or parang dumadaan ka sa lubak pero naeencounter ko sya pag umaabot ng 2000 rpm pataas tas pag nag shift ako nawawala then babalik pag asa 2000 rpm na naman.. nagpalita na ako ng engine support pero meron pa din.. me nagsabi sa akin na wheel bearing yung iba naman camber allignment naman.. ano kaya problema??
    Quote Originally Posted by jocampo10 View Post
    Mine was usually associated with speed and the noise would occur when I hit 40kph or when I was turning. As I would speed up, the noise would also go faster until I reached 8kph from where the noise would be fast enough to be just a big droning hum.
    Jul 2011
    Damages:
    Wheel bearing - 1k
    Pressing - 250
    Labor - 250
    Tip - 50
    san shop mo pinaayos?
    Jan 2014
    Quote Originally Posted by K.I.L.L. View Post
    ahh.. wala po bang vibration? yung parang nalulubak ka?
TIRE NOISE DURING ACCELERATION - Chug, Chug, Chug
