Results 1 to 20 of 22
    Jul 2003
    bakit kaya mas pudpud sa loob (front tire), defective ball joint kaya any comments...
  2. FrankDrebin Guest
    Over-inflated?
    Jan 2004
    both tires ba sir? baka naka-negative camber ka?
    Jul 2003
    Quote Originally Posted by ian_rex View Post
    driver side only, maspudpud sa inner part...
  5. FrankDrebin Guest
    Maraming dahilan brader. Pinakamaganda dyan ay visual inspection ng mechanic.
    seems na naka-negative camber na siya. have an underchassis/suspension expert check the alignment.
    Jan 2004
    then correct as necessary.
    Quote Originally Posted by acenie View Post
    check mo muna alignment mo, malamang negative camber ang front. Worst, isang front tire lang ang negative so medyo delikado. then kapag maayos naman ang camber setting mo, saka mo naman pa check the rest of the suspension component.
    Jul 2003
    Quote Originally Posted by Karding View Post
    OO alignment yata, kasi pansin ko kumakabig siya sa right side passenger side... sana hindi ball joint kasi mahal..
    Jul 2003
    nagpunta na ako sa Goodyear ito yung mga na detect na sira sa VAN ko:
    1 pc Upper Link Shaft (left) - 1,100.00
    1 pc Ball joint (right, upper) - 550.00
    1 pc Side Rod - 1, 450.00
    1 pc. Center post 1,800.00
    Labor:
    upper link shaft - 429.00
    Ball joint upper -347.00
    side rod - 265.00
    center post - 343.00
    Alignment:
    toe - 466.00
    caster - 188.00
    2 camber -1082.00
    Total: 8,020.00
    Any comments or suggestions on this!!!
    Aug 2005
    Labor:
    side rod - 265.00
    Alignment:
    toe - 466.00
    caster - 188.00
    2 camber -1082.00
    Total: 8,020.00
    2nd opinion bro.. uhmm.. servitek.. go go..
    Sa L300 mo ba yan sir? Problema talaga ng L3 yung center post. Yung sa L300 van ko dati, dinala ko lang sa machine shop yung lumang center post housing at nagpa press fit ng brass sleeve thus eliminating the plastic bushings. Just make sure na may hole parin yung sleeve para daanan ng grease sa fitting. Madali kasing madurog yung bushing e.
    Kung kailangan talaga palitan yung mga parts, para makatipid ka, DIY mo nalang yung mga kailangan palitan tapos sa shop ma nalang pagaw yung alignment. Ganun lagi ginagawa ko e. Matitipid mo na yung labor.
  13. FrankDrebin Guest
    Labor:
    side rod - 265.00
    Alignment:
    toe - 466.00
    caster - 188.00
    2 camber -1082.00
    Total: 8,020.00
    Try ninyo po sa Wheelers for 2nd opinion.
    Apr 2006
    goodyear (servitek) is quite reliable about their finding, but parts and labor comes pricey compared sa parts straight from auto supply. i suggest pgawa mo lahat sa yong suking mekaniko then go to goodyear for alignment services nalang. IMO goodluck
    Jul 2003
    up!up!up!up!
Tire (mas pudpud sa loob)
