Page 8 of 11 FirstFirst ... 4567891011 LastLast
Results 141 to 160 of 299
    mahal ng 215/50/17 na C.Drive.... 6200 per tire sa freddy's! :whoa:
    Mar 2003
    6200 pesos? pare isnt that the going rate for the other tire brands of the same size as well? sana for the mainstream tire sizes, competitive ang price nya. kaya ko nagustuhan yang c.drive na yan kasi its a new tire, tapos assymmetric pa yung tread pattern, less hassle sa tire rotation
    Falken Z512 - 5050/tire
    Dunlop LM702 - 4700/tire
    Yokohama C.Drive - 6200/tire
    Bridgestone Potenza G3 - 5750/tire
    prices as of last weekend. pinakamahal talaga yung C.Drive. yan pa naman balak kong kunin. kelangan mag-ipon pa ng konti.
    Jun 2004
    wow, those are pretty expensive, and i thought the Goodyear NCT 3 at around 2600/tire is expensive! (195/65 r15)
  5. #5
    Ilan ply yung mga tires na yan?
    Dec 2003
    Clarification lang po these prices are for 17's right?
    Jul 2003
    what do you prefer Wrangler or Maxmiller to a Van tires
    I used GJ Maxmiller's (spelling ?) on our L300 pero for a short time lang. Mas road-biased yun kaysa sa Wrangler na pwede for off-road use.
    yup, 215/50/17
    Jul 2003
    OTEP,
    Anong size ng maxmiller ng L300 niyo. ok ba ang 185R14 or 195R14. anong pinakabest na size ng L300.
    Jan 2003
    changing stock crv 2k2 215 to 225, mas matadtad ba?
    feeling ko mababawasan ang tagtag. yan sabi din ng mga ibang V owners when they changed to wider tires with same sidewall thickness.
    Nope... wider tires will also increase your sidewall height a bit.
    kapag same sidewall ratio (e.g. 60) tapos wider tires - medyo mas kakapal yung sidewall mo - kaya pwede ma lessen yung tagtag nga talaga...
    btw, the rav4 2.0L is using 235/60/16. baka gusto mo gayahin... mukhang kaya naman ng cr-v yun ganun kalaki...
    if i increase my tire size lets say from 185/65/14 to 195/55/15
    do i also have to increase my tire pressure? dati 30 psi ang nilalagay ko sa mga gulong ko
    Quote Originally Posted by benchph1
    bro, tingnan mo yung tire pressure guide sa may driver's door mo. usually for sedans it will vary from 28-36.
    yung fronts alam ko steady 30 yata. then yung likod lang nag vavary. pero 30 is the best guestimate for any vehicle's tire pressure.
    225/45/17 tires ko. i use 33 psi on all 4's
  18. #18
    hello mga sirs...and mams!
    i just wonder..
    kasi im planning na to change my Kelly multitrack 30x9.5 R15 tires i have now...im considering
    1.dunlop grandtrek a/t2
    2.bridgestone dueler a/t
    3.yokohama geolandar a/t + II
    of them i ruled out the dunlop...because of the feedbacks i've heard..(kasama ung mga dealer na di nagrecomend nun)kaya im left with the two...
    im confused what to get..they're good tires..which do you all recomend?
    and ask ko lang din...im considering this also...im planning to have
    235/75R15LT size on the front and 30x9.5R15LT size on the rear..
    is this set-up wise..considering my rear tires is 1.12204 inches higher and 0.24803 inches wider than my front tires?(planning not to rotate the front to rear tires,vice versa)or it is best to keep the sizes same for all tires..
    thanx in advance!
    teka... para sa anong kotse yan?
    bridgestone duelers a/t are kinda ok naman... oem tires yan ng mga mini-SUVs (CR-V, Rav4). kaso nakakasawa na tingnan kasi pare-pareho kayo.
    pero based sa specs mukhang mas ok yung geolander. ako na dismaya sa specs ng dueler nung nakita ko sa bridgestone website na sobrang dami pa palang variants ng dueler (low-end yung binebenta dito).
  20. #20
    for my 4wd van(delica)...gusto ko nga sana dueler a/t revo..but cant find one and not available here,e..just got a pair of 235/75r15LT geolandars for my front tires for P10,120(tires,2 pito,16pcs lead,mags repair-->nasa other thread po ung breakdown,e.."which a/t tire" thread)mura kaya ito?
    pinamount ko na ung while letters ay sa loob at ung black ay ung nakikita..
    ask ko lang kung sa rear tires naman same size din or 30x9.5r15LT...will the 1 in height and .25 inch wide difference matter?
    thanx po..
The Tire / Gulong Thread [Merged]
