Page 1 of 11 12345 ... LastLast
Results 1 to 20 of 299
    Jan 1970
    mga peeeps! ano ba mgandang goma ngayon? ang dami brands ngayon, good year, yokohama, michelin, bridgestone. ano ba sulit bilin for city driving lang. slamat ! ;)
    what size? dimensions?
    gamit ko ngayon bridgestone potenza g3, 205/55/16
    pero ok din ang LM702 ng dunlop or kung high end gusto mo, mag FM902 ka.
    michelin, falken and toyo, ok din.
    kung di ako nagkakamali REVO ang ride mo...
    ito lang advice ko...don't buy Good Year NCT3 tires...masyadong maingay lalo na sa concrete road...
    For what car are you looking for?
    My tires of choice would be Bridgestone, Dunlop and Yokohoma.
    Chieffy, add poor wet road performance and threadwear to the cons of the NCT3s.
    parang hazardous to ur health ang NCT3 :lol:
    Jan 1970
    no magpapalit ako ng gulong ko for lancer itlog. baka pati mags na rin. baka mag 15" nko tpos yokohama na goma 50 series ok ba un?
    Jan 1970
    guys tanong nga pala? ano ung mga numbers na nakalagay sa gulong before yung series and yung size? example: 195... , 205...., 165..., 185...
    I have Hankook Ventus Sport K104. Great wet traction (I've tested it ;) ) Not bad price wise too. http://www.hankooktireusa.com/index.html
    Mar 2003
    ako gamit ko gajah tungal ok naman gang ngayon! kulang kc budjet ko....
    All about TIRES.
    Tire Dimensions:
    The first number is the width of the tire in millimeters, measured from sidewall to sidewall. To convert to inches, divide by 25.4 In the example above, the width is 185mm or 7.28".
    The second number is the aspect ratio. This is a ratio of sidewall height to width. In the example above, the tire is 7.28" wide, multiply that by the aspect ratio to find the height of one sidewall. In this case, 185x0.60=111mm or 7.28"x0.60=4.36".
    The last number is the diameter of the wheel in inches.
    To figure the outside diameter of a tire, take the sidewall height and multiply by 2,(remember that the diameter is made up of 2 sidewalls, the one above the wheel, and the one below the wheel) and add the diameter of the wheel to get your answer.
    Example...185/60R14 85H or 185/60HR14
    185mm x .60=111mm x 2=222mm + 355.6mm(14")= 577.6mm or 22.74"
    http://forums.nasioc.com/forums/show...hreadid=322553
    Speed Rating - Miles/Hour - Kilometers/Hour - Typical Use
    N=87 MPH, 140km/h, Spare Tires
    P=93 MPH, 150km/h
    Q=99 MPH, 160km/h, Winter, LT Tires
    R=106 MPH, 170km/h, LT Tires
    S=112 MPH, 180km/h
    T=118 MPH, 190km/h
    U=124 MPH, 200km/h
    H=130 MPH, 210km/h, Sport Sedans
    V=149 MPH, 240km/h, Sports Cars
    Z=149 MPH, 240km/h and over, Sports Cars
    W=168 MPH, 270km/h, Exotic Sport Cars
    Y=186 MPH, 300km/h, Exotic Sport Cars
    quote from Tirerack.com
    And I'm using the Yokohama AVS-ES100 W speed rating. 215/45/17
    Jan 1970
    Yes, there are many good brands out in the market today such as Michelin, Goodyear, Pirelli, Bridgestone, Dunlop, etc... But remember that every brand has both good and bad tire models.
    May mga okay na Goodyear tires and may mga bad na Michelin tires for example. When I was in the market for new tires, I found the tire review section at www.tirerack.com to be very helpful.
    Yung pinili ko in the end was the Pirelli P400. It's cheaper than the NCT3 nang goodyear but outclassed it in every category (dry traction, wet traction, durability, noise, etc).
    Yung gusto ko sanang bilin was the Michelin X1 but nobody seems to be selling it here sa Philippines.
  12. #12
    ano the best for 215/45/17? balak ko palit size ng gulong at wheels eh. Currently in using 195/60/15 H rating na Bridgestone Turanza SS50
    Anybody here using Yoko ES100?
    How's the noise?
    artpogi, Im using a Yokohama AVS-ES100 more quiter than Falken. I used to run with Falken ZIEX but maingay ang madaling maupod...madulas pa.
    phillipogi, biased ako so I'd say Yokohama AVS-ES100 :p If I could only afford the Yokohama Parada Spec 2 when I got my new set of wheels, I would have gotten those instead.
    stay away from NCT3s
    Bridgestone Potenza G3 has good reviews.
    sidenote about tires..
    ano preference nyo? Directional o non-directional tires? and why?
    Jan 1970
    In my case, Nondirectional syempre :-)
    Its more practical since you only have to carry one spare tire. If you get a flat on the left side or right side you can use the spare. Kung directional ka, you may have to unmount the tire from the wheel ,remount and rebalance it. Hassle.
    Besides, ang dami kong nakikita na mga directional tires mounted backwards.... this is a big safety problem. Not only will the tires wear out much faster pero baka biglang bumigay at speed. Nondirectional tires eliminate this risk.
    phillipogi,
    try mo mag upgrade to 225/45/17...mas ok ang traction and mas makapal ang sidewall for better protection sa rims mo
    meron pa bang available na high-performance tires na non-directional?
    may point ka dun hagiber... i have directional tires right now... might have to buy non-directional next time... though my spare tire is mounted on a steel rim (hence iba talaga gulong ko dito...eheheh..)... for the same reason you pointed out.
    wala na atang non-directional na hi-perf tires.. H-rated na ata ang pinakamataas. not sure though.
    hagiber, pirelli cheaper than the NCT3? magkano exactly tsaka saan? magpapalit na rin kasi ako ng tires eh.
    pipol, eto mukang ok bgo ng yokohama.
    Yokohama launches ‘AVS deciBel’ silent tire
    If you crave high-performance grip and stability in a tire but loathe the noise from aggressive tread patterns and special compounds, Yokohama may have the tire for you with its new AVS deciBel lineup.
    The latest addition to the premium AVS product range, deciBel was conceived by engineering Yokohama’s Advanced Vehicle System technologies and focusing on producing one of the quietest tires in the market today.
    Designed as a low-noise, all-around tire, deciBel (or simply "dB") features Noise Simulation Technology, a unique tread pattern designed with five-pitch variation to minimize hammering tire noise, and tread blocks to suppress noises generated by tire wear.
    A new Silica Tread Compound featuring Yokohama’s proprietary "Zeruma" processing agent disperses silica consistently for optimum grip in both wet and dry conditions. Four straight and wide grooves are also incorporated to minimize aquaplaning.
    As part of Yokohama’s premiere AVS lineup, the deciBel is available in 15- to 18-inch diameters, 35- to 65-series aspect ratios, and "V" (maximum of 240 kph) up to "Y" (maximum of 300 kph) speed ratios. 205/55R16 tires up to 265/35R18 models also come with Rim Protector bars. Prices range from P5,900 for the smallest 195/65R15 95V all the way to P14,700 for the 235/40R18 91Y.
    Yokohama Rubber Co. Ltd. of Japan recently announced that its Philippine tire manufacturing and marketing subsidiary would upgrade its facilities to boost production beginning April. By the end of 2003, annual capacity will expand from two million units to 2.5 million at a cost of around two billion yen.
    Production of 16-inch and larger high-performance passenger car and recreational vehicle tires will be stepped up for growing international demand. It is expected that 30 percent of production by year’s end will be composed of the 16-inch and larger models.
    About 90 percent of Yokohama Tire Phils.’ output is exported to Europe, the Middle East and other ASEAN nations with the balance for the after-market and Japanese automakers in the Philippines.
The Tire / Gulong Thread [Merged]
