Results 1 to 16 of 16
    Actually, I've already tried both ways in our 323.
    Most of the front suspension parts was replaced by Rapide a few years ago... a bit pricey at 20K++. The rear suspension was taken care of Zee a few months ago to the tune of only 4K++. Am actually satisfied with both jobs.
    For the Rav4, it seems that the ball joints and stabilizer link has already deteriorated. The estimated cost of replacement of this parts (original) is around 9K only.
    Though I am also thinking of just having this repaired since I am pretty sure that the bill for this would not surpass 1/3 of the cost of replacement.
    What do you think guys? Ok kaya ang repair for a Rav4?
    Thanks,
    Kung ako pare, palitan mo na. Sigurado ka sa bnew parts ;)
    AKo din brand new. Una mo check yun budget muna.
    depende yan sa budget ng total repair bro.... kung medyo magkalapit na lang yung cost, replace na... tama si pk, sure ka pa sa parts.
    kayang kaya ni pareng M2 yan mga peeps
    Aug 2004
    Repaired ball joints? No. A friend did this with their Galant, and it wore down after a while. Replace them... it's better than spending a little now and still having to replace them after a few months.
    brand new original parts ka na lang and enjoy the peace of mind while using your ride.
    Jan 2004
    i agree. palit ka na lang ng brand-new. you'll never know how extensive the damage of the parts, if you decided to have it repaired only. besides, once you replaced the parts with a new one, chances are, matatagalan na ulit ang pagpapalit mo dahil maayos na ang NLEX. of course, ingatan mo din sa mga speed bumps and potholes.
  9. #9
    you mean you guyz won't recommend zee or cruven?....pag dito ba sa cruven or zee..tumatagal ang repaired shocks?
    thanks,
    city
    sakin depende sa kotse and parts price.
    in your case M2, i'd just replace it, 9K for everything isn't that bad for OEM parts.
    pero like sa case ng W123 ko dati, if i purchase 2 shocks, aabutin ako 6K, kung paparefill ko, 1400 lang, dun nalang ako sa 1400... it's an old car kasi, lugi kung bago pa pyesa.
    Aug 2005
    gusto ko replace ng orig talaga pero depende talaga sa budget.. =(
    Bago oto - OEM pyesa
    Luma oto - surplus, 2nd hand, repair
    Apr 2004
    mag-1 year na halos yung pinarepair ko sa pang ilalim ng pajero ko ke zee, solid pa din
    if i may, i did this b4 w my nissan & i estim8d d serviceable lyf of d repaired part in proportion 2 d cost vis-a-vis d serviceable lyf & cost of oem parts. if d proportion differs by just abt 20% +/-, den i will go for oem considering d peace of mind & performance satisfaction of having all oem parts working harmoniously in ur ride.
    Apr 2004
    even at 50% diff i would certainly suggest getting OEM..but usually this is not the case, difference in repair job often time costs 100%++ less compared to getting OEM
    Feb 2005
    *slamtaz- bawal po txt/sms type/talk
    I opt to have it repaired for my old car. If I had a newer car, I might go for a brandnew part.
    Had my rear dampeners repaired, plus new boots for P1760.00
Suspension... Replace or Repair?
