Results 1 to 16 of 16
  1. #1
    Guys,
    I had my exalta STA inspected by carguard in Alabang westgate due to vibration or scraping noise happening everytime i make a right turn. the owner suggested refacing the brake discs because it's already worn and uneven. Do you guyz recommend these?
    Need you expert opinion...thanks in advance!
    regards,
    city
    Ok lang basta nde pa manipis.
    yep ok lang yan..
    Apr 2004
    yes ok lang yun.. as long as di masyado ninipis
    Oct 2005
    oks lang! first time refacing is good...
    tapos replace shoes and pads para hindi masayang ang refacing. magiging ganun din kasi ang kayod sa refaced surface kung hindi mo papalitan. mas madaling magwe-wear.
  6. #6
    thanks guyz!...is this a simple job ...i mean most shops do this?...medyo concern lang kasi ako baka hindi maayos ang pag-reface e....gusto ko yung pulido ang gawa...first time ko kasi sa carguard alabang...anyway, how about casa? nagrereface din sila?
    regards,
    city
    Quote Originally Posted by city
    regards,
    city
    tamang tama you're from the south...sa servitek ako nag papa reface. meron talaga silang machine for rotor refacing. kalimutan ko lang kung mag kano inabot.
  8. #8
    thanks sun!
    city
    Oct 2005
    600+each ata sa likod at 700+each sa harap...
    Aug 2005
    Quote Originally Posted by umzzzzz
    4 discs brakes po ba ang nissan STA?
  11. #11
    Quote Originally Posted by finchy18
    yes.
    BTW, i had my problem re-checked and it turned out that hindi disc brake ang problema....I'm hearing vibrations or ugong when turning right because of a damaged wheel bearing!....grabe..kumakalog yung gulong as in....buti na lang napaayos agad...haaay..i felt relieved...
    I bought the wheel bearing for P3000+...japan made....i paid for the part and replacement job at Carguard Alabang..the mechanic is good. he knows what he's doing...labor is P350..
    vibration/scraping noise gone!
    Thanks for all your posts peeps!...mabuhay kayong lahat!
    Regards
    city...
    reface na po yan.
    and on the rotor itself, usually near the center, nakalagay dun the minimum safe thickness ng rotor. as long as it still goes above or equal that thickness after refacing, it's still okay. but personally, i'd rather have it above the min. thickness than exact min. thickness just for peace of mind.
    Aug 2005
    galing.. nice one..
    Aug 2004
    Hehe... akala ko pa may help akong maibibigay, being a previous STA owner... oh well.
    3000 ang wheel bearing?
    laki ng kita nila sayo ah
    Nov 2003
    yeah kinda expensive... at least they found the correct problem tho.
Brake Discs for reface?
