Page 1 of 2 12 LastLast
Results 1 to 20 of 24
    Aug 2003
    Got home late last night to find our car sort of "leaning" towards one side. ok naman ung tires....ung shocks kaya?
    if it is the shocks, by pair ba talaga ung replacement nyan? And can someone recommend a good enough brand? i'm not into the tuning/performance thing btw, basta't ung ok lang for ordinary driving
    kyb gas-a-just!
    imho, it could also be the springs.
    inspect the shocks kung may fluid or gas leak tapos do the bouncy-bouncy test.
    Originally posted by pajerokid
    ...do the bouncy-bouncy test.
    hahaha... natawa ako dito... oops... OT... :D bad mod!
    Kalampag ba pwde bang cause yun nang shock?
    Saka maalon sya eh. pero pantay naman yung stance.
    Thanks.
    imo, yes..diba mazdamazda? nung sira na shocks ko, pag nalubak habang mabilis takbo, may malakas na blag sound..
    Got Mazda?-http://www.MAZDAtech.org [SIZE="1"]est. 2000[/SIZE]
    got mazda 2? -> mazda2ners
    Aug 2003
    caloyski:imo, yes..diba mazdamazda? nung sira na shocks ko, pag nalubak habang mabilis takbo, may malakas na blag sound..
    hmmm, ganung nga ung nangyayari sa kin
    mazda mazda,
    Pagpasensyahan mo na si PK medyo sossy yan eh.... hahahahaha
    PK - Peace tayo
    Jan 2004
    shocks(spring) or shockabsorber?
    Jan 2004
    Thanks.
    musta bro? pag kalampag, bushings yan, normally sa trailing arms.
    bouncy, shock absorber.
    Feb 2004
    Yung sa akin naman nawala ang bounce after camber/wheel balance/alignment sa Servitec alabang.....pinag practisan yata ng mga uhugin doon...Palit ako ng shockabs sa harap pareho.........
    Tanong lang po....mas mura po ba ang mga aftermarket shockabsorber sa mga shop kesa sa OEM ?
    Jan 2004
    normally yes. basta may slight na upgrade sa performance ok lang yung after market, basta orig. OEM kasi mahal na pero same rin ang performance. depende sa iyo. ako honestly, gusto ko OEM kasi i try to maintain the stock version ng car ko.
    sa bouncy-bouncy test ba, ang pagkaka alam ko is sira ang shocks mo kapag nag bounce ng ilang beses ang shocks?
    or baligtad? kapag hindi nag rebound ng ilang beses yung shocks yun ang sira?
    medyo naguguluhan ako...
    yung mazda ko ngayon eh mabagal mag rebound yung likod na shocks...
  15. FrankDrebin Guest
    Paano naman yung "bouncy-bouncy test" sa mga naka-lowering springs?
    "bouncy-bouncy test" - (bagong word ito ha?) pwede yata ito kapag dumadaan sa mga humps? pakiramdaman mo ang bounce sa front and rear shocks mo.
    luther, tama. sa bouncy-bouncy test, pag nag bounce ng ilang beses, sira ang shocks.
    Ian, ok naman kaso may problem ako sa car ko eh sa harap at likod.
    Palit na ako Trailing arm bushing kaso M7 saka buong trailing arm assembly.
    Pagmabilis or di naman ganun kabilis tama lang pag nalubak may blag na sound.
    Ano kaya yun shock kaya.
    Thanks.
    Nov 2003
    malamang kung sa m7 mo ginawa yan they used solid bushings to replace the factory ones.
    noise and harshness is a tradeoff. mura nga pero you have those annoying sounds to deal with.
    Jan 2004
    Up ko lang po... Question sa bouncy-bouncy test...
    Pag first time, nag-bounce twice, tapos after mag-settle in a few seconds, try ulit, hindi na nagbounce (I mean bumalik agad sa normal position), sira na ba or malapit na?
time to replace shocks?
