Results 1 to 13 of 13
    Dec 2007
    Patulong naman po mga tsikot gurus. Kaninang umaga nang pinaandar ko sa garahe yung starex ko, napansin ko na pag iniikot ko yung manibela, anumang direksyon, uugong at may konting vibration yung makina. May tunog din akong nadidinig (not sure where exactly it's coming from) hindi ko alam kung paano i describe pero kasing tunog ng naka engage na break at pilit na iniikot yung gulong.
    Para masigurado na sa steering wheel ang dahilan ng kakaibang tunog, inatras abante ko siya at the same time steer. Confirmed nga na may steering problem. Nang bumaba ako, nakita ko sa ilalim ng sasakyan na madaming fluid na tumagas...apparently, tumagas siya habang atras abante ko siya.
    Ano po sa tingin niyo ang sira niya? Posible kayang mahal ang aabutin ng repair kung sakali.
    By the way, tuwing weekends ko lang ginagamit ito, at last weekend di ko siya nilabas. Related kaya ang cause ng problema sa di araw araw na pag papaandar sa kanya.
    Thanks in advance.
    Quote Originally Posted by Kikomann View Post
    Thanks in advance.
    malamang may power steering repair kit para jan. mura lang ata yun. kung nde na kaya ng repair kit, dun ka mapapagastos ng malaki...
    Thanks in advance.
    hi kikomann, here are some of the threads that discussed PS prob. you can try searching more if you wish
    http://tsikot.yehey.com/forums/showt...power+steering
    ipacheck mo agad yan sa mekaniko mo
    para wala nang sakit ng ulo
    possible causes
    rack and pinion
    lines ,hoses , pump or reservoir
    May 2007
    Visit this site..
    [SIZE=3]Troubleshooting Guide[/SIZE]
    ... when turning wheel with car stationary on ground and engine running ... Intermittent loss and recovery of power steering. Sudden loss of power steering ...
    www.woodwardsteering.com/trouble.htm
    You won't lose that much fluid overnight if the leak is coming from your gearbox or pump. COuld be that you have a busted hose wherein turning the wheel makes it lose more fluid because of the pressure built-up.
    Dec 2007
    Thanks sa mga responses ninyo. Actually papaluwas na ako ng Manila noong nadiscover ko iyong problem kaya wala na akong time na i check pa kung saan naggagaling iyong leak. Ipinagbilin ko na lang na tumawag ng mekaniko at i check. After reading the links related to my problem, it made me feel that it's most likely a busted hose at tumagas iyon ng marami nang i ikot ko yong wheels. I just hope na kayang gawin ng mekaniko sa amin at di na kailangan pang dalhin sa casa para di na ako gumastos ng malaki. My van is now 4.5 years and travelled 116 thousand kilometers kaya out of warranty na at hanggat kayang gawin sa labas, hindi ko na siya dadalhin pa sa casa na sobrang taas magpresyo.
Help! Power steering tumagas
