Results 1 to 10 of 13
- Dec 2007
- 16
August 26th, 2008 05:53 PM #1Patulong naman po mga tsikot gurus. Kaninang umaga nang pinaandar ko sa garahe yung starex ko, napansin ko na pag iniikot ko yung manibela, anumang direksyon, uugong at may konting vibration yung makina. May tunog din akong nadidinig (not sure where exactly it's coming from) hindi ko alam kung paano i describe pero kasing tunog ng naka engage na break at pilit na iniikot yung gulong.
Para masigurado na sa steering wheel ang dahilan ng kakaibang tunog, inatras abante ko siya at the same time steer. Confirmed nga na may steering problem. Nang bumaba ako, nakita ko sa ilalim ng sasakyan na madaming fluid na tumagas...apparently, tumagas siya habang atras abante ko siya.
Ano po sa tingin niyo ang sira niya? Posible kayang mahal ang aabutin ng repair kung sakali.
By the way, tuwing weekends ko lang ginagamit ito, at last weekend di ko siya nilabas. Related kaya ang cause ng problema sa di araw araw na pag papaandar sa kanya.
Thanks in advance.
August 26th, 2008 07:58 PM #2
August 26th, 2008 08:00 PM #3
hi kikomann, here are some of the threads that discussed PS prob. you can try searching more if you wish
http://tsikot.yehey.com/forums/showt...power+steering
THE AUTO SPECIALIST
- Mar 2006
- 607
August 26th, 2008 08:46 PM #4ipacheck mo agad yan sa mekaniko mo
para wala nang sakit ng ulo
possible causes
rack and pinion
lines ,hoses , pump or reservoir
August 27th, 2008 03:09 AM #5
Visit this site..
[SIZE=3]Troubleshooting Guide[/SIZE]
... when turning wheel with car stationary on ground and engine running ... Intermittent loss and recovery of power steering. Sudden loss of power steering ...
www.woodwardsteering.com/trouble.htmLast edited by v6dreamer; August 27th, 2008 at 03:12 AM.
August 27th, 2008 05:28 AM #6
You won't lose that much fluid overnight if the leak is coming from your gearbox or pump. COuld be that you have a busted hose wherein turning the wheel makes it lose more fluid because of the pressure built-up.
- Dec 2007
- 16
August 27th, 2008 10:22 AM #7Thanks sa mga responses ninyo. Actually papaluwas na ako ng Manila noong nadiscover ko iyong problem kaya wala na akong time na i check pa kung saan naggagaling iyong leak. Ipinagbilin ko na lang na tumawag ng mekaniko at i check. After reading the links related to my problem, it made me feel that it's most likely a busted hose at tumagas iyon ng marami nang i ikot ko yong wheels. I just hope na kayang gawin ng mekaniko sa amin at di na kailangan pang dalhin sa casa para di na ako gumastos ng malaki. My van is now 4.5 years and travelled 116 thousand kilometers kaya out of warranty na at hanggat kayang gawin sa labas, hindi ko na siya dadalhin pa sa casa na sobrang taas magpresyo.
August 27th, 2008 10:47 AM #8
Basta po sa mga reputable shops kaya yan. Libre naman ang check-up, if in doubt you can also try and compare for the casa estimate - you’re last resort if the part (if for OEM) is not available in local auto supplies.
- Dec 2007
- 16
August 27th, 2008 10:59 AM #9Sorry for my ignorance pero can I drive the vehicle so that I can bring it to a reputable shop around 10 km away from our place? Is it possible na baka lumaki lalu ang sira niya?
August 27th, 2008 11:45 AM #10
^^^It can as long as di matutuyuan ng ATF/PS fluid on the way. dala ka na lang ng pang top up para wag magka hangin. good luck
Traffic!
