Results 1 to 10 of 10
- Nov 2010
- 6
November 17th, 2011 09:31 AM #1hello mga sir, share ko lang problem sa car ko,,makalampag kc ung car ko at parang nagmumula sa rear bumper ko. Naisip ko baka lumuluwag na mga screws.. gusto ko sana iswap na lang rims ko e kaso ayaw ni misis kc maporma daw at un nalang nagdadala...so nagdecide ako baka makuha sa pagpalit ng shox..ano po ba mgandang brand and ung mura?? Car po namin is 92 Nissan Eccs. thanks and God Bless.
- Dec 2009
- 225
November 17th, 2011 10:00 AM #2
November 18th, 2011 07:46 PM #3
pa check mo yung mga bushings baka worn out na, next is shock absorber baka wala ng play at ubos na yung gas or fluid, next is yung tire baka naka low profile kayo, makalampag talaga yan..imo lang naman..
- Jul 2003
- 573
November 19th, 2011 10:28 PM #6
the less rubber, mas less din ang shock absorbing ability ng tire.....like in my case, i was running M//Ts before then switched to A/Ts. lesser driving comfort.
- Jul 2003
- 573
November 20th, 2011 12:52 AM #7Check if anything loose is being stored in the trunk, secure them all or provide some cushion
Check rubber bushings
Replace shocks insulator block.
Replace shocks shaft bumper.
If budget permits, replace with new rear shocks.
November 20th, 2011 07:44 PM #8
vibrations come in various types when you start modifying or stray from oem specs...
some of these modifications are"
1. Lifting the vehicle effecting increased driveshaft angles
2. Larger tires can also increase steering and geartrain components. a bigger tire will require greater effort to turn causing accelerated wear and tear of steering and suspension components.
an unbalanced tire or low air pressure may have great effect on steering and stability.
Follow a systematic diagnosis.
1. air up the tires
2. check suspension mounts, steering gear mounts, shock mounts, tie rod ends, ball joints.
3. check the movement of steering parts by having someone steer the wheel back and forth.
4. (others may want to continue the list)
- Nov 2010
- 6
November 22nd, 2011 11:31 PM #9uhm,,pakiramdam ko parang wala na akong gulong e,,parang rim na lang sumasayad sa kalsada..plus nga ung kalampag sa bandang rear bumper. Gigil na nga ako magpalit ng gulong e, kung di lang dahil kay misis,,jejejeje...
- Nov 2010
- 6
November 22nd, 2011 11:35 PM #10mga sir, specially kay sir mike,
lulupit po ng mga suggestions. very much appreciated po talaga mga payo ninyo.. sabi na nga ba dito ako makakakita ng kasagutan e...thank you po sa inyong lahat and God bless!!
3M Crystalline vs 3M Ceramic IR: Which is Best for Your Car? I think Crystalline might be...
