Results 1 to 10 of 34
- Jun 2013
- 120
June 17th, 2013 10:46 PM #1Good day. My new AT CR-V slips backwards even after pressing the foot brake (full force). What I do to test is go uphill, stop, set to neutral then put on the foot brake. Honda technician said that it does happen because of the weight of the vehicle. Is what he said true, or should I have my car picked up and checked in casa?
- Jun 2013
- 120
- Jul 2003
- 573
June 17th, 2013 11:35 PM #3normally, in going uphill or in steep incline, you should apply the hand brake. foot brake is not strong on the rear wheels. foot brake is designed to stop the car while moving forward, and applies strong braking force to the front wheels only.
June 17th, 2013 11:38 PM #4
I think sir sparton is referring to foot brake not the brake pedal. No hand brake available.
- Jul 2003
- 573
June 18th, 2013 12:31 AM #5interesting, does the foot brake in a CR-V replaces the normal hand brake lever? If so it should lock the rear wheels and prevent the car from
moving. If it slips, then it definitely needs adjustment.
Sparton, when the car moves, can you tell if the wheels are sliding/slipping or turning?
- Jun 2013
- 120
June 18th, 2013 12:43 AM #6Sorry for not being clear. I'm referring to the foot-operated parking/emergency brake. As far as i can remember, the wheels are not sliding nor turning. Just rolling backwards. But for some weird reason, parking brake seems to work when going downhill. The dealer technician said that it can be because of gravity especially because of the vehicle's wait. I may need to have them pick up my car for casa checkup.
June 18th, 2013 03:17 AM #7
the technician is wrong
a brake is a brake and what it does is to bring your car in full stop whether in uphill or downhill, moving forward or backward. but then, if the wheels are not even sliding or turning? how can it roll backwards without the wheels turning?
then it might be the tires? maybe there is no more traction so no more grip on the surface...
- Jun 2013
- 120
June 18th, 2013 10:27 AM #8
BANNED BANNED BANNED
- Jul 2003
- 2,267
June 18th, 2013 10:38 AM #9maybe it just needs an adjustment.
but even if thay have it fixed, never trust a parking/emergency brake when you park your vehicle in an incline road.
shift it to P or for manual tranny into 2nd or 1st gear.
- Jun 2013
- 120
June 18th, 2013 10:49 AM #10
Had my 2014 Altis repaired by Tireman PH in Gen. Trias, Cavite last Wednesday. Nawala na yun...
rack and pinion repair
