Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Nov 2007
    Mga kuya, help naman. Naging rough po kasi yung ride ng Honda City namin. I noticed it lately. Parang hindi balanced yung wheel or may na-bend ata sa suspension namin. Wala naman po ako ibang matanungan coz my mom doesn't care at all and wala rin friend na may alam about these things. Baka po may kilala kayong mechanic na pwede namin papuntahin sa amin na taga-las pinas/alabang area lang po. Hindi po kasi ako makapunta sa hongly or cruven kasi walang kasama, baka maloko pa ako or something. again po, help....
    Quote Originally Posted by samejicon View Post
    hmm... panong rough? paanong hindi balanced? do you hear something kung nalulubak? parang impossible naman na bend sa suspension. most likely something gave na pangilalim. when you turn, do you hear any sound? does your steering tend to wiggle when you go pass 40 km/h?
    the only thing na masasabi ko sa decription mo ng rough is you have busted shock absorbers, sira yung mounts or nawala na integrity ng springs mo. yung isang side ba lower then the other? medyo hirap diagnose yan kung yun lang description. can you be more specific?
    Nov 2007
    Quote Originally Posted by archie123456789 View Post
    wala naman pong prob when turning pero driving on a straight line, parang may isang flat na gulong(kahit wala naman).
    most probably, your car would need a wheel alignment/camber.
    since ayaw mo magpunta ng cruven sucat and taga las pinas ka, dalahin mo sa either servitek (in front of toyota alabang) or minerva tires (filinvest area...)
    also try to check if your tire pressure is consistent, meaning, dapat lahat ng tires eh pare-pareho ng bigat.
    i dont think anything is wrong with your car, if the front left side is lower than the front right side, thats kind of normal because of the engine weight tends to lean on the left side. if you what, a lifter can solve your prob pero pacheck mo na din just to be safe.
    as id4lv said, go to servitek kung ayaw mo sa curven or hongly. just act as if you know stuff about cars para hindi maloko.
    Nov 2007
    Quote Originally Posted by 1D4LV View Post
    hindi po ba bad service dun sa servitek? May nabasa po kasi ako dati na naka-experience ng masama dun. Saan po malapit yung minerva?
    Nov 2007
    hindi po sya sa may driver's side. hmmm, parang mahirap yata on my part na magpanggap na may alam sa kotse. Baka di maconvince kasi bata pa po ako.
    theres no sound coming from the wheels or suspension? baka naman paranoid ka lang. hehehe yung view mo ang disturbing ba? when your driving straight, para bang nakalean ka sa left or right?
    hmm... curven kasi ok talaga sa pangilalim na probs eh. wala na ko ibang marerecomend na shop sa south aside sa hongly.
    di naman. dyan din ako nagpapa align eh....
    yung minerva sa eastgate ng filinvest. malapit sa gonuts and chevy alabang.
    ganito na lang bro...
    on wednesday morning, i will be in cruven sucat (to have my rear bushings fixed..) if you want, i can meet you there so para ma assure ka na hindi ka lolokohin (although, hindi manloloko ang cruven sucat...)
    that way too, i can have your car test driven para madetermine na rin natin kung ano talaga ang problem.
    Nov 2007
    no sound po. Dati kasi smooth pa yung ride, lately parang pilay. Although ako lang yung nakapansin kasi wala naman paki mom and friends ko about cars. Basta may magamit, ok lang. Yung right side yung may problem. Hopefully this week mapagawa ko kasi sumasakit katawan ko sa kotseng yun.
    Nov 2007
    hindi po ako sure sa wednesday, may susunduin po kami sa airport sa hapon. Hindi ko rin po kasi alam kung saan banda yang cruven. If ever magpunta po ako mag-isa lang ako, and baka umaga po. What time will you be there po? Btw, Girl po me kuya 1D4LV.
    sorry. yung cruven sucat is right in front of paranaque municipal high school. going to the airport from evacom, its at your left, so kailangan mong mag u-turn dun sa tapat ng olivarez college. from the airport, its at your right, after olivarez. ang reckoning point mo is yung sm sucat.
    most probably i will be there before 9 am para maaga matapos. may lakad pa kasi ako sa afternoon eh.
    just send me a pm if you will be there.
    mukang may date kayo ha? hehehe joke lang.
    mas ok na rin na may kasama ka sa curven para sure hindi ka maloko.
    reguarding sa rough ride mo, most probably shocks na yan.
    goodluck!
    Nov 2007
    ah ok po. Mahal po ba sila maningil dun? Baka mapagastos ng wala sa oras. Ipapacheck ko po muna mga sira ng car ko.(dumadami na ipapagawa--may dalawa din kasing bangga)
    Sige po kuya, pm kita pag punta ako.
    Nov 2007
    goodluck!
    nyek.
    Sana hindi malala yung sakit. Baka magkasakit din ako eh.
    they charge reasonably. labor cost is average, but ang makakamura ka is sa parts.
    ipacheck mo muna. they do free estimates. and pag napasubo ka na, they accept credit cards... hehehehehe.
    Jan 2008
    -check first your tire pressure.
    -then ask someone to push down one at a time each of the front fenders, the car should not bounce twice or more. pag nag bounce sya twice or more, shocks might need replacement. try to check din kung lumalabas na fluid ng shocks (if fluid type).
    Last edited by enzo18; March 10th, 2008 at 07:08 PM. Reason: added some more infos
    nyek.
    hindi pa naman siguro masakit sa bulsa yung repiars niyan... how old is the car? kung less than 8-10 years yan. ok lang kasi nagsisimula mag wear and tear and pangilalim starting sa 7+ years ang oto. which is why puro ipon ako ngayon para mabalik sa brand new condition ang car ko... :ouch:
    Nov 2007
    Ah ok po. Thanks!^^,
    Nov 2007
    Quote Originally Posted by enzo18 View Post
    ok po. try ko next time.
    Hindi ko po lang sure kung fluid type ung shocks.
suspension/wheel problem
