mga sir ano maramdaman pag may crack na suspension bushing,left and right,front.usually how much parts and labor nito?galing kc ako sa mechanic for wheel alignmnt kaso sabi pagawa mmuna raw bushing bago alignment.tnx
mura lang ang rubber bushing at labor. pag sira na yung bushing may maririnig ka either TOK sound or grinding steel sound parang umi-itit. ang ipalit mong bushing yung polyurethane type para mas tumagal.
Sometimes there are no symptoms or tell-tale signs of worn/cracked bushings. Anyways, you can just crawl under the vehicle and visually check the bushings' condition.
^^how much would it cost to replace them (civic '96 vti)?
ano nga ba effect nito kapag matagal di napalitan ang mga bushing?
ah kaya pala nabanggit sa akin dati na kelangan pa daw ipa-machine shop pag replace ako ng rear suspension bushingspomelo says:
Yung pag palit ng bushing, have it pressed kase pag pinupuk-pok, nasisira yung butas kung saan pinapasok ang bushing.
