Results 1 to 15 of 15
    para sa mga di nakakaalam, i have an altis 1.6 04.
    my plans:
    convert front and rear to gas shock absorbers
    drop it by 1.5" using proper lowering springs
    replace bushings at the rear
    done:
    gas shocks front (excel g)
    replace bushing front
    balance all wheels
    rotation every 10k km
    replace ball joints and stab links at the front
    my queries:
    is it required to have an alignment everytime something is change/replace at my suspension?
    does an altis have stock camber/caster adjustment? or if i lower it by 1.5", i have to install camber/casket kit on it if its not equipt? or can a shop (like servitek) do its adjustments? a mechanic(servitek) told me that my altis is not equipped with a camber/caster adjustment something, and they do it at the shocks (dinuduga daw sa shocks parang ganoon).
    what are the cause of wiggling/vibrating steering wheel at 100kph?
    thanks in advance. back to square one ako.
    A minimal drop shouldnt require a camber/caster correction kit AFAIK (CMIIW). If your camber is off and it cannot be adjusted, some shops shave (kikil) the shock bolt area to allow some play for adjustment. Mine so far has never needed any such adjustment (52,000kms).
    On the vibration, have your wheel balancing checked again. Thats the usual culprit.
    Alignment is needed when major parts are changed or moved (shocks/control arm brought down, tie rods/rack ends replaced).
    The temptation to install H&R lowering springs on my Altis has always been there. My 1993 Sentra B13 on 13" rims and stock everything handles better. :P Only thing keeping me is that i find the tall ride height and long suspension play oh-so-useful in our types of roads.
    thanks for the reply sir vinj.
    i recently replaced my stock shocks becuase its broken. so do i need to have an alignment?
    With the new shocks, yes. If you were just aligned recently it may be done for free if youre still under warranty. Sabihin mo lang may kabig pa rin.
    Jun 2010
    may adjustment ng camber ang altis.kailangan mo palitang ng bolt and nut yun sa knuckle arm para maadjust yun camber nun or kailanagn mo kikilin mo yun butas ng bolt...
    wiggle/vibration of steering wheel has gone after the 2nd wheel balance. tried a 140kph run at nlex. no wiggle.
    so for the mean time, no need for wheel alignment.
    maybe after rear shocks, rear bushing replacement and install lowering springs,then ill have wheel alignment.
    *lexxus, thanks sir.
suspension of altis 04
