Results 1 to 12 of 12
    Apr 2010
    Hi, mga sir's ask ko lng po kung ano magandang gawin sa sobrang lambot na rear suspension springs, kc madalas ko napapansin na sumasayad ung body sa gulong pag may lubak or road humps, ano po ba magandang gawin remedy dito? TIA.
    Jul 2011
    Baka naman wala na ung shocks mo, pa lift mo para makita kung buo pa.
    Hula ko din shocks.
    May 2009
    baka mabilis ang rebound kamo sir TS at hindi malambot.
    kung sumasayad na, kadalasan nanghihina na mga springs. ang shock absorber e anjan para icontrol lamang yung pagrebound ng sasakyan.
    Pacheck mo shock absorber. If okay naman, add ka na lang rubber lifters (donut shape) para tumaas. Thats the cheapest way to do it. Just dont buy yung rubber na sinisingit lang sa springs.
    Jul 2006
    Teka,
    Anong kotse ba ito?
    Feb 2009
    Quote Originally Posted by johnkeight08 View Post
    over time, as the car ages, some suspension components get tired. be it torsion bar springs,coil springs, leaf springs and specially air springs. if the gross weight of the car far exceeds that of the rated weight without upgrading the springs, the springs go into accelerated "tired" height. it does not matter if you change the springs to the same oem type if the gross vehicle weight is too much, it too will have the same effect. maybe your passengers are too "healthy"
    Apr 2010
    thank you po mga sir's sa reply btw po the car is a honda city i-dsi, will have the springs check pra matignan ko na din ung rubber nya thanks po...
    Feb 2009
    are your tires the original size and the tire inflation pressure specs followed?
    Jan 2014
    suspects: (in my opinion)
    1st: Putok Shocks (Springs do most of the work)
    2nd: Tires
    3rd: Other components
Super lambot na rear suspension?
