Results 1 to 5 of 5
    hi,
    i've split my tie rod ends from the knuckle and held the tie rod/rackend up. when i release it, it immediately drops down. is the a sign of wear that needs replacement na?
    Jul 2003
    if they can be moved without noticeable resistance, yes they are in need of replacement.
    yup, no resistance. the only resistance that i have is the pure weight of the tie rod/rack end being pulled down by gravity.
    Feb 2009
    Quote Originally Posted by spyghost View Post
    hi,
    spyghost,
    bad people don't die easy and you're too darn lucky to be alive. replace worn steering components soon as you hear noises and feel erratic driving. you don't have to squeeze the last penny's worth of those components. it is like playing russian roullette with an M9 (FN92) pistol.
    jick
    very good point
tierod/rack end dropping when released - worn?
