Results 1 to 10 of 28
- 441
July 27th, 2003 02:33 PM #1i experience this with the safari,bago naman suspension components nya,medyo nakakatakot eh,parang kakalas,although not often,pero when your in high speed,then medyo uneven yun road or my bump,nag wiwiggle sya..what could be the prob.?this is the local safari and not those converted ones.i usually experiance this prob. with converted cars lang kce. although naayos naman sha,pero i wonder with this local safari.i was thinking about the stabilizers eh.
- Jul 2003
- 579
July 27th, 2003 03:29 PM #3tire balance. alignment. stabiliser (but it sould not do that even without the stabiliser)
July 27th, 2003 05:49 PM #5
Baka nasanay ka sa IFS. Sa LC namin medyo ganyan din compared sa Pajero pero tolerable naman.
July 27th, 2003 06:04 PM #6
or baka rin naman may bukol isa sa mga tires mo....ganun ako dati....lahat na ginawa ko...hindi ko alam posible pala mag wiggle coz of a bukol sa tires.
- 441
July 27th, 2003 08:32 PM #7ok,ill check on the stabilizers..mukhang yun nga eh..how much ba to?yun replacement lang.and papa tire balancing ko narin.pro meron pa kce shang mga tinga from the old tires.
otep,
whats IFS?
glennster,
hindi naman cguro,3 wks old palang grandtrek AT2's nun on all for corners eh.
anyway,thanks again guys.
July 27th, 2003 09:48 PM #8
IFS = independent front suspension. Solid axles ang mga Patrol, eh.
- Jul 2003
- 579
July 27th, 2003 11:18 PM #9nikko m, try to solve the problem without the stabilizer. the stabilizer is meant to keep the steering wheel from turning when you hit rocks etc. it just hides problems not cure them.
look for the problem and fix it. try rotating tires, balancing them, check if out of round, alignment. don't rely on the stabilizer. you might be changingsomething that doesn't need to be changed. I'm using old man stab. pero until I get my tires balanced right, may problem pa rin.
- 441
July 28th, 2003 12:01 AM #10otep,
oic,so whats the diff.?is it one of the reasons on why the suspension of the patrols are very stiff?as in stiff?
bubbles,
ok,thanks man.
Ayala North Exhange. May parking levels siya na available for the public. Then may RCBC, GT...
Makati CBD parking
