Results 1 to 14 of 14
    Anu ba cause nun? Old tires? Wheels not aligned? Or other steering prob?
    Parang Daytona 1 & 2/GT Force feedback pero d naman kalakasan... tama lang pro hindi exaggerated.
    It can be caused by a lot of things, when do you feel the wiggle?
    Nov 2004
    wiggle pag nalubak or uneven road? suspension problem malamang. meron ko dati nito. pinaayus ko suspension kay zee back to normal na ulit.
    Aug 2005
    check mo din brakes mo
    as what artpogi said, let the thread starter give details on when he experiences the wiggle, at what speed, at what kind of road, etc.
    mahirap na baka advice tayo ng advice, tapos yung thread starter, pa-check ng pa-check. lalaki lang gastos nya.
    Oct 2004
    kung hindi rack end or tie rods, pwedeng yung steering linkage coupling or yung cross joints....
    Oct 2005
    Quote Originally Posted by EssB View Post
    most likely
    Sep 2005
    Quote Originally Posted by ineedmorehp
    sir,
    it could be all or one of these things:
    please have your trusty mechanic check it first before spending...
    1. old, worn out, damaged, and uneven tread wear of tires
    2. damaged rack end or tie rod end (for rack and pinion steering)
    3. damaged pitman arm, centerpost or idler arm (for gearbox steering)
    4. damaged suspension arms
    5. damaged ball joints
    6. damaged or weak shocks
    7. damaged or loose hub bearings (spindle)
    8. misaligned camber, toe in or toe out, or caster
    9. damaged wheels
    hope this helps...
    Thanks for the replies.
    shock new, spring front new, rear stock.
    I havent check steering stuff.
    Tire is 5-6 years old na...
    Tingin ko kasi gulong. Pero posted it here para malaman ko other possibilities.
    Sep 2005
    yes sir, tires may expiration din. kahit makapal pa....
    Apr 2006
    tires nga siguro pki explain kng kailan nag wiwigle pag mabilis llng ba pag ganun chexk the air pressure yun lng yun
    Quote Originally Posted by jasprit
    Pag umaandar forward/backward. Air pressure checked - ok naman.
    Aug 2006
    Have your front tires rebalance.
    I rotated the tires pa X. Dont know if the proper way though it solved the probl. Haha... change tires na 'to...
    eto medyo OT: which is better:
    Potenza G3 or ES100
    195 or 205 ba or 215?
Steering wheel wiggle
