Results 1 to 5 of 5
  1. #1
    Guys ano kaya problema.. kasi may play yung steering wheel ko.. pag inikot onti papuntang left from straight position.
    parang 1inch yung play.. kanina pinaayos ko yung centerlink ko pero ganun pa rin.. ano kaya culprit?
    Jul 2003
    baka preload adjustment ang kailangan niyan.
    pero check mo din kung may play na ang rack ends o tie rod ends.
    Quote Originally Posted by cokezero View Post
    Either the tie-rod ends or bushings are worn out. Just have it inspected and replaced if needed.
    Feb 2009
    first, since the subject vehicle is not properly identified, it is safe to assume that it has parallelogram type steering.
    you mentioned centerlink that makes it not cross steer, not haltenberger, not rack and pinion, not centerpost type steering.
    check your idler arm and pitman arm, or perform a dry park test (done with another person feeling the linkages for looseness while another person turns the steering wheel back and forth slightly)
  5. #5
    salamat sa mga reply
    kanina kasi tnest yung steertimg wheel.. inikot ikot tapos nakita yung sa center link daw loose so yun ang inayos..
    okay pa daw yung tie rod..
    anyways isuzu ls yung kotse ko.. sabi ng isang mechanic baka daw crossjoint?
Steering Wheel Play
