Results 1 to 10 of 14
- Apr 2009
- 16
April 15th, 2009 08:48 PM #1Ano kayang problema sa EK00 ko? May kabig pa-kanan yung manibela. Sa straight road, pagbinitawan ko yung manibela, pumupunta pa kanan yung kotse. Pina check ko na ang wheel alignment, ok naman daw...Pansin ko mas mababa yung left side (driver portion) ng body kaysa sa right side. (2 fingers sa left, 3 sa right). Thanks in advance.
- Jul 2003
- 573
April 15th, 2009 09:07 PM #3perhaps the front of the car have unequal weight distribution? one side is heavier which results in height difference.
- Apr 2009
- 16
April 15th, 2009 10:02 PM #430psi ang tire pressure ko. Wala pa namang major accident whatsover.
Related kaya yung height difference pati yung kabig ng manibela pakanan?
April 16th, 2009 02:42 AM #5
It sounds like either the wheels are out of alignment, the right tire is low or the right brake is binding.
April 16th, 2009 08:08 AM #6
- Apr 2009
- 16
April 16th, 2009 08:00 PM #8Yep..Pagbinitawan, kakanan na cya.
I believe common problem ng EK ang di balance ang left sa right, but I'm not sure whether the other owners also experience yung kabig pakanan ng manibela.
- Apr 2009
- 16
April 20th, 2009 07:29 PM #9Guys, pumunta ako sa bridgestone para i-pacheck ang aking suspension. Sabi nila sira na daw yung ball joints kaya daw may kabig. Tapos, nakita nilang sira na rin yung stabilizer (eventhough di related sa kabig). They are charging me 5.8k for the replacement of the ball joints (left & right), stabilizers (left & right) and wheel alignment.
Question: Fair lang ba yung price na naquote sa akin? Thanks. Magkano kaya kung sa ordinaryong talyer ko ipapagawa? Thanks.
- Sep 2007
- 215
April 21st, 2009 08:29 AM #10pwede balljoint and problem ... pero ndi pa rin kakabig ... siguro bagsak yung isang side ... try mo rin pa check yung shocks mo ... baka stock up kaya ganun
Banawe Auto Supply
7120115
regy
Monk-owned R53
