Page 1 of 2 12 LastLast
Results 1 to 10 of 18
    Nov 2006
    something weird happened to my car's power steering last night. suddenly it went squealing...parang napupunit na fan belt tapos pag-kabig left/right my krug,krug sound. but when i stop the car and check, buo naman fan belt at wala ako makita leak. then pag-andar ko uli nawala na yung ingay. even after a 1-1/2 hr drive kanina umaga from residence to work wala na yung ingay. ano kaya yun?
    Aug 2009
    check your power steering fluid........
    Baka worn out na o ready for replacement na power steering hose mo.
    Nov 2006
    Quote Originally Posted by speed unlimited View Post
    fluid at normal level, hose is visibly ok, no leaks. iniisip ko baka kaya barado somewhere along the line?
    Quote Originally Posted by lancer5790 View Post
    Dirty PS fluid? Try to DIY flush it.
    Nov 2006
    nangyari ulit paguwi ko kagabi from work. mukhang pag nakasindi mga ilaw lumalabas yung problema. ok naman mga belts...pwede kayang alternator though hindi naman umiilaw warning light?
    Dec 2007
    I suspect a bad CV joint or two.
    Nov 2006
    Quote Originally Posted by Type 100 View Post
    got both cv joints replaced last month only sir. i think it's the PS belt. physically good pero baka worn out na actually. baka slippery na rin.i tried tightening eh nawala yun ingay. ill just have to replace it today then observe ko ulit. thanks sa inyong lahat...
    Nov 2006
    mga sirs, more inputs please...the problem gets going on. nakapagtataka lang the squealing occurs after about an hour ride with the lights on. i thought it was an alternator problem so i opened the alternator but it was in good shape. the last resort im thinking is flushing the PS fluid...
    Nov 2006
    update lang po. ok na yung power steering ko. all i did was to clean the PS pump then replaced the PS fluid. presto-smooth as ever ulit ang power steering...thanks a lot to you guys!
squealing power steering
