Results 1 to 5 of 5
    Apr 2009
    Hi tsikot members..
    My ride is Isuzu Crosswind 2001. I just noticed this when i had my muffler replaced at mufflerland. yung sa ilalim ng Gearbox ( where naka connect ang steering rod). medyo basa siya looks like a slight leak on ATF. yung ATF ko parang hindi naman nagbabawas.
    Is this a problem na puede kong huwag muna paayos? due to budget contraints.
    and can you give me an idea how much paayos leak. I think the seals have to be replaced.
    thank you
    Just make sure you have adequate fluid in the reservoir. I've been taking care of a similar case for a few years now. Adding some ATF every few weeks or so.
    Apr 2009
    Thank you Sir Otep..
    Jan 2012
    yup need to change oil seals and fix the cause which are your suspension reason why your steering leaks, check this they have warranty on steering repairs
    http://www.**************/index.php/...ION+SPECIALIST!
    Apr 2009
    hi ppj can't open file. what shop you recommend? do you have contact number?
    so you mean the cause of the leak is due to suspension defect? if ever leak on gear box is repaired it will come back if I don't first fix
    my suspension problem if ever?
    thank you
Power Steering question - Gearbox has leak
