Results 1 to 5 of 5
- Apr 2009
- 539
February 7th, 2012 06:01 PM #1Hi tsikot members..
My ride is Isuzu Crosswind 2001. I just noticed this when i had my muffler replaced at mufflerland. yung sa ilalim ng Gearbox ( where naka connect ang steering rod). medyo basa siya looks like a slight leak on ATF. yung ATF ko parang hindi naman nagbabawas.
Is this a problem na puede kong huwag muna paayos? due to budget contraints.
and can you give me an idea how much paayos leak. I think the seals have to be replaced.
thank you
February 7th, 2012 06:26 PM #2
Just make sure you have adequate fluid in the reservoir. I've been taking care of a similar case for a few years now. Adding some ATF every few weeks or so.
- Apr 2009
- 539
- Jan 2012
- 12
February 25th, 2012 02:06 PM #4yup need to change oil seals and fix the cause which are your suspension reason why your steering leaks, check this they have warranty on steering repairs
http://www.**************/index.php/...ION+SPECIALIST!
- Apr 2009
- 539
February 29th, 2012 12:07 PM #5hi ppj can't open file. what shop you recommend? do you have contact number?
so you mean the cause of the leak is due to suspension defect? if ever leak on gear box is repaired it will come back if I don't first fix
my suspension problem if ever?
thank you
