Results 1 to 10 of 10
    Nov 2007
    guys, my steering is making some squeaking noise everytime na pnihit sya nang sagad (left or right) or not even that sagad. I had it checked, hinigpitan ang PS belt but still the squeaking noise is still there lalo na pag sagad ang liko and when not power assisted (pag di nag momove ang car).
    tiningnan ko rin ung belt pag nililiko nang sagad, parang naiiwan sya at hindi kumakagat dun sa crank.....is this due for replacement? mahigpit na ung ginawa nung mekanik eh......
    thanks!
    Nov 2006
    Quote Originally Posted by cliffy1523 View Post
    thanks!
    same problem with my corolla, the mechanic told me, the problem is the power steering pump, the other one told me belt lang daw...i'll have another mechanic check the car tomorrow
    Nov 2007
    sa tingin ko normal lang yan pag old corolla na ganyan din yung aking white corolla XE 92 MODEL buti nga sa inyo umiingay lang saken nangagatog at minsan namamatay ang engine
    Dec 2007
    Hello po mga boss. newbie lan po. ganyan din ang experience ko ngayon sa KIA PREGIO ko whenver na ililiko ko sya right or left me tumutunog sa Power Steering po ba yun? pano po ba malalaman kung dapat ng paayos ang power steering? nde po ba delikado yung ganon pag ginagamit? thanks po. and hope to learn from this forum again.
    May 2007
    Heto ang gawin ninyo.
    Check power steering fluid, bring it to proper level.
    Check power steering belt tension at least 1/2 play when you push it down w/ your finger on the middle. Do not over tighten the belt it could damage your pump.
    Bleed your power steering by turning lock to lock your steering w/ your engine idling left to right until that squeeking sounds gone. While doing this constantly cheking your fluid for proper level, add if necessary. good luck boys.
    Jan 2008
    ganyan din problema ng corolla ko
    yung unang mechanic sabi yung hose. pinalitan nya ng hose..
    yung 2nd mechanic sabi belt. hinigpitan belt.
    yung 3rd mechanic sabi power steering pump. pinaayos ko with new kit. no parin naaalis yang sound na yan!
    ano pa ba pwede paghinalaan?
    anyway, thanks to v6dreamer for that tip. i'll try the bleeding thing until my nose bleeds.. hehe.. thanks bro.
    Jan 2008
    Quote Originally Posted by v6dreamer View Post
    sa akin naman '00 GLi, ok naman fluid level, tension ng belt, nagawa ko na rin bleeding with the reservoir's cap on and off. pero meron pa rin.
    Jul 2006
    V6dreamer is right on the money.
    However, sometimes if the belt is really old, the rubber will become slippery. When I was doing vacuum pumps for belt driven units we had to sand the belt surface of the pulley in order to get more bite out of them. Sand them perpendicular to the orientation of the belts, to make some teeth out of the pulley. When in doubt replace the belts with new ones, clean the pulley surfaces, follow V6dreamer's advice and replenish the fluid. If your P/S system has a tensioner it might also be due for replacement if it's not putting enough tension on the belts. Then tighten the belts to spec, overtightening will destroy the bearings.
    Nov 2007
    Quote Originally Posted by gerard25 View Post
    try these things if it will work
    1. kung luma na ang belt replace it with new one (minsan ang belt kapag manipis na it produced squeezing sound sa pulley)
    2. tighten the belt (tamang higpit lang)
    3. pour PS fluid at max level
    4. switch on the engine in idle mode then iliko mo sa kanan at kaliwa pabalik balik kung may bula meaning may hangin lang, magdrain ka ng fluid para mawala ang hangin.
    5. check mo na din baka may leak ang mga hoses, kung mamasa masa meaning may konting leak.
    Ganyan din kasi ginawa ko sa pregio ko ang culprit ay belt, hindi ko kasi inuna ang belt.
    up ko lang. may ugong or squeeking noise truing 1/2 of my steering wheel to the left. it is big body '94 GLI corolla
Squeaking Noise while turning
