Results 1 to 8 of 8
    Nov 2007
    I noticed that my car's steering got heavier and I hear a "squeaking" sound everytime I turn the steering wheel. do you guys have any idea what the real problem is? I'm gonna have it checked soon but I don't know any reliable shops who does great jobs on this. I live in Las Pinas. What shops do you suggest(around las pinas and alabang area)?
    May 2007
    your steering fluid maybe low. Add if nescessary.
    Dec 2007
    Quote Originally Posted by samejicon View Post
    Please check your power steering fan belt, it might be loose. what you have to do is to tighten it.
    Nov 2003
    is the noise from inside the car or outside? that would be 2 totally different things kasi
    Nov 2007
    Quote Originally Posted by speedyfix View Post
    it's from the inside. bandang part ng steering wheel. is it possible na dahil may kabig na steering wheel?
    ubos na yung powersteering fluid mo ... or try palitan yung powersteering fluid to a better one .....
    check mo kung may powersteeringt fluid ka pa ... kung wala na maytagas na yung rackend pinion mo or yung powersteering hose mo ...
    BANAWE AUTO SUPPLY
    7120115
    regy
    Apr 2006
    almost same issue here. sorry if maki-ride dito
    squeeking when steering. tapos when i open the PS tank, bumubula ang fluid at kulay chokolate na. i add a little until enough level pero ganun padin.
    help naman please. thanks
    note: if belt yun, san po location?
    car: nissan california , converted to PS
    May 2004
    try replacing and changing the fluid. much better kung ma drain maigi and ma-flushing yung old fluid inside.
squeaking steering
