Page 15 of 15 FirstFirst ... 51112131415
Results 281 to 296 of 296
    Jun 2005
    #281
    Kung mag cruven ka din naman, sa main branch ka na nila pagawa sa crame.
    Dont get me wrong. Lagi ako nagpapagawa sa cruven pero sobra sablay yung cruven fairview.
    Either cruven makati or crame na lang ako.
    Sep 2014
    #282
    Quote Originally Posted by RavGirl View Post
    Good evening sirs,
    It's my first time here and I need advise po how much Toyota genuine parts and where I can buy below items.. My car need the following:
    Need to replace right away:
    2pcs Front shocks
    2pcs Rear shocks
    2pcs Stab clamp bushing
    2 front and 2 rear brakes
    2pcs Tie rod
    2pcs Rack end
    2 Front Wheel bearing
    2 Rear bearing
    My Car is 2004 RAV4. 1.8 M/T. And how much would it cost me for the labor to have all these replaced. And ano po replacement parts? Sorry I don't have any idea about these things. My friend used to help me but he moved to US na so I feel so lost. Appreciate all your good recommendations. Thank you.
    Dapat sinana na din upper and lower balljoint as well as stab links. Complete suspension overhaul na to hehe
    Im just curious pano kaya takbo neto sa kalsada, malamang sa last 5 years sira na mga eto
    _________________________________
    If you are wrong, turn right.
    If you are right, turn left.
    #283
    errr... what tires are you using now, po?
    is it possible, them tires are simply too big for the car, kaya sumasayad?
    sabi nga sa akin noong nagpavulcanize ako dapat daw 55 series, kasi 60 yung gamit ko ngayon. pero kasi dati di naman masyadong sumasayad, ngayon lang madalas
    #284
    Quote Originally Posted by sirkosero View Post
    noted sir. madami nga rin ako nabasa na negative reviews though may mga positive reviews din. nabigyan ako ng quote na umabot sa 23k. refill ng shocks, replacment ng mga rear bushing, engine support, rack end at tie rod, plus brake pads. reasonable ba ito? or mas mura kung sa iba ako bibili ng parts labor na lang sa kanila?
    Jun 2005
    #285
    Dati nagpaquote ako sa fairview branch, inabot ng 30k ang quote. Pati power steering may sira daw so plus plus pa.
    Dinala ko sa zee (kapatjd ng owner ng cruven).
    8k lang for everything. Wala naman sira yung power steering
    Wag ka magpaparefill.ng shocks. Always go for replacement shocks. Madali masira yung repaired and refilled shocks nila.
    Buy the shocks and other parts yourself. Sobra laki matitipid mo.
    Maganda injection ng joints ng cruven and zee.
    Stay clear of fairview branch.
    #286
    canvass muna nga ako ng parts eh, tapos punta ako sa kakilala kong mekaniko pa check ko sa kanya lahat ng tinuro ng cruven kung palitin na nga ba kasi kung ako lang, yung rack end lang nakita kong sira na talaga maliban doon sa langitngit ng gulong sa likod na ewan ko kung shocks nga ba o makukuha sa bushing lang. thanks, sa reply sir!
    ok ba iyong cruven sa sucat?
    what do you mean by injection points bro?
    Aug 2016
    #288
    ask for your recomendations guys, san shop kaya for replacement shocks ng bmw 320i 2006? thanks
    Jun 2005
    #289
    Experience nila utol, ayos naman sa sucat. Never tried it there though. Layo eh. Makati branch ako lagi. Kilala ko na din mekaniko eh.
    Yung injection nila ng joints is parang refurb ng worn out joints. Nilalagyan nila ng bagong plastic sa loob ng joint para sumikip uli.
    Based on experience, mas matagal masira than the 555 replacement na nabibili ko dati. Tapos may 1 year warranty naman kaya okay na din.
    ^ bale lumalabas ba na mas mura kapag nag injection ng joints vs 555 replacement parts ang gamitin?
    Sent from my ASUS_Z00AD using Tsikot Forums mobile app
    Sep 2016
    #291
    Balak ko magpalit ng Amade Extreme shock absorbers for our 08' Hilux. Any feedback guys sa ganitong brand ng shocks? Salamat po in advance!
    Oct 2016
    #292
    Hello! 1st timer po here.
    Nung Saturday nabangga kami sa may Bridge dahil may tumalon na pusa nagulat.
    Tapos tumabingi yung gulong sa Right Side Front. tapos kapag nag ddrive ang luwag na nung sa manebela ramdam na ramdam lalo na kapag paliko. dinala namin sa Toyota North Edsa, ang sabi papalitan daw yung Shock Absorber. Mga magkano kaya aabutin?
    Quote Originally Posted by sushi123 View Post
    Toyota Wigo G AT po pala ang sasakyan
    Feb 2012
    #293
    Ok naman po ba ung pusa diba nasaktan? Haha joke lang po.
    Mukhang nawala sa allignment. Better balik nyu kung saan nyu pinacheck po ang wigo nyu baka delikado gamitin? Kung shock lang naman di naman siguro sobrang mahal nun.
    Sent from my SM-N910G using Tsikot Forums mobile app
    Mar 2017
    #294
    Quote Originally Posted by erdiedizon View Post
    Hello Sir,
    Any ideas po if how much ang KYB shocks EXCELG for toyota vios 2nd gen yr 2010.
    And yung bushing kaya how much din,
    Thanks! papalit sana ako dahil matunog na siya pag dumadaan ako sa humps.
    #295
    Quote Originally Posted by benjo3733 View Post
    Hello Sir,
    You may call Toyorama in Banawe.
    Mura lang yung rear shocks mga 1K+ each. Front shocks mga 3K+ each.
    May 2017
    #296
    My left front shocks are already leaking and needs to be replaced. Any suggestion for a good shock replacement for Ranger XLT 2013 A/T? Any suggestion for shops na din in Banawe?
    Thank you.
shock absorber replacement
