Ask ko lang mga sir kung ok lang ba na lagyan ng langis yung underchasis bushing
^ Use high quality grease.
Fasten your seatbelt! Or else...Driven To Thrill!
you must be using aftermarket suspension bushing that are not rubber. many a times when the engine oil or power steering fluid leaks and makes contact with stabilizer bushings, control arm bushings, stabilizer linkage bushings, they always swell up and melt. this is a common sight when you have petroleum leak. the rubber boots used in the birfield joints and ball joints are not of the same formulation as that of suspension bushings.
rubber has many different formulations. nitrile and neoprene are more tolerant to petroleum. rubber for use on tires and suspension components are neither nitrile nor neoprene based. if the suspension bushings were made of polyurethane, you can use all the petroleum oil your little heart desires but it will not hurt the polyurethane as much. your oil seals and valve oil control seals are made of neoprene
there are many kinds of rubber, both natural and synthetic. the rubber seals used in the engine are not the same as the bushings on your suspension. those in the engine are oil resistant, the ones in your suspension are not. as mentioned above by jick, you can use silicone spray. your best bet however is silicone grease, like the lubricant used for O-rings.
