San ok mag pa reface ng brake discs dito sa QC?
Posted via Tsikot Mobile App
Fb ladao ( bridgestone timog) look for gerry
Not sure, pero it shouldn't cost more than 1200 for the pair.
Iirc, i paid 1k when i had my car's rotors refaced.
When I still had the 2007 Ford Escape, it cost me 700/pair at Shell Diliman station. Try inquiring at Shell stations near your area to get the cheapest cost. Usually, they already have contacts of shops that will do the job.
Thanks. Ang mahal sa PowerTorq, 900 per pc and 250 for the pull down per pc.
bakit hindi ka nalang bumili ng bagong brake disc , kasi kung refaced pa, kapag manipis na hindi na rin masyadong makapit ang brake pads , gagastos ka rin lang naman sa mekaniko e sure ball mo na yong mga brakes para isang gawaan nalang.
Tried powerstop rotors. Ok naman since my previous rotors were worn out na. Pero in hindsight, I should have bought a fresh surplus rotor para OEM spec pa din.
Meron sa Banawe corner Macopa, across Campershell, refaced the brake rotors of my Corolla GLi there, tanggal at kabit nila, P1k lang yata pay ko, more than a year ago.
Motech Fairview may refacing machine, yung Petron Commonwealth may nakontrata na machine shop. Or kung natanggal na, you can just bring it to any reputable machine shop in your area. Siguro P500/disc.
Rotors and drums can be machined or resurfaced as many times as long as the rotor does not fall below minimum thickness and the drums not go beyond maximum diameter. The specs are either embossed, stamped or cast into the drums or rotors.
Nakiki wi-fi lang
