Results 1 to 14 of 14
    May 2010
    San ok mag pa reface ng brake discs dito sa QC?
    Posted via Tsikot Mobile App
    Feb 2005
    Fb ladao ( bridgestone timog) look for gerry
    May 2010
    ^how much yan sir?
    Feb 2005
    Not sure, pero it shouldn't cost more than 1200 for the pair.
    Iirc, i paid 1k when i had my car's rotors refaced.
    Jun 2007
    When I still had the 2007 Ford Escape, it cost me 700/pair at Shell Diliman station. Try inquiring at Shell stations near your area to get the cheapest cost. Usually, they already have contacts of shops that will do the job.
    May 2010
    Thanks. Ang mahal sa PowerTorq, 900 per pc and 250 for the pull down per pc.
    bakit hindi ka nalang bumili ng bagong brake disc , kasi kung refaced pa, kapag manipis na hindi na rin masyadong makapit ang brake pads , gagastos ka rin lang naman sa mekaniko e sure ball mo na yong mga brakes para isang gawaan nalang.
    Aug 2013
    Meron sa Banawe corner Macopa, across Campershell, refaced the brake rotors of my Corolla GLi there, tanggal at kabit nila, P1k lang yata pay ko, more than a year ago.
    Motech Fairview may refacing machine, yung Petron Commonwealth may nakontrata na machine shop. Or kung natanggal na, you can just bring it to any reputable machine shop in your area. Siguro P500/disc.
    Jun 2014
    Quote Originally Posted by Rob O. Bravo View Post
    How much does a piece of rotor usually cost? Is there a recommended after market brand? Thanks!
    May 2010
    Well, as per Speedlab's advice, discs can be refaced twice in it's service life.
    Feb 2009
    Rotors and drums can be machined or resurfaced as many times as long as the rotor does not fall below minimum thickness and the drums not go beyond maximum diameter. The specs are either embossed, stamped or cast into the drums or rotors.
    Nakiki wi-fi lang
    Jan 2003
    Tried powerstop rotors. Ok naman since my previous rotors were worn out na. Pero in hindsight, I should have bought a fresh surplus rotor para OEM spec pa din.
    Jun 2014
    Quote Originally Posted by non-vtec View Post
    Do you still have an idea how much yung powerstop rotors?
Brake discs refacing in QC
