Results 1 to 12 of 12
  1. #1
    I bought 2 new rear tires 2 years ago. Strange only one tire (left wheel) wore off faster than the other one.
    ANy inputs?
    thanks guys
    br,
    city
    Feb 2005
    Go to the shop and check the wheel balance or the wheel alignment.
    Apr 2006
    saan part ng gulong un wear?
    alignment prob nga yan.
    pacheck mo including camber.
    Aug 2006
    Quote Originally Posted by jundogg View Post
    +1 on the alignment and check if you need new camber/s
    Nov 2006
    anong klaseng tire thread wear yan,,,,feathering,cupping,one side wear,centerline wear,outer tread rib or shoulder wear?
    A related question...
    My rear tires would wear faster on the inside since the Rav4's rear has a negative camber setting. The wear on the rear tires is quite noticeable if you forgot to rotate your tires (guilty!) every now and then.
    To salvage the tires, what I did is to have them unmounted, flipped them (so that the outside is now in the inner side) and then mounted them again to the wheels.
    Is that ok?
    P.S.
    My better tires (almost brand new) are in front and I am hesitant to move them back because of this.
Tire Wear
