Results 1 to 10 of 14
April 19th, 2006 04:00 AM #1
Ride: Civic '99 VTi
Quick question: Kung nagpalit ako brake pads kailangan na rin ba palit ng brake shoe sa rear wheels?
Salamat sa input niyo. Sorry po sa babaw ng tanong ko. newbie lang po sa cars.
April 19th, 2006 04:43 AM #2
normally yes...but you or the mechanic can always check if there really is a need to have the shoe or pad replaced kase may indicators naman.
sabay mo na para isang trabaho nalang. if you never had problems before (like stuck ups) then go change all 4 and save yourself the hassle of worrying when the others will be due.
HTH
April 19th, 2006 10:04 AM #3
depende din yan kung kailangan na talaga palitan yung brake shoe. as what beetols said, pa check mo nalang sa mechanic mo kung kailangan na talaga palitan.
April 19th, 2006 10:16 AM #4
not really. alangan naman palitan mo yung break shoe kung makapal pa naman silang lahat same with the break pads. pero kung isa sa mga pads or break shoe ay damaged na or manipis na, palitan mo na lahat.
April 19th, 2006 10:46 AM #5
kung makapal pa yung shoe kahit ‘wag muna basta i-note mo na dapat uanhin mo siyang ipa-check before yung pad sa front. Pwede rin palit lahat pos next time monitor mo kung sabay nga sila mapudpod then you can do adjustment for the next check-up.
Tsikot Member Rank 5
- Nov 2003
- 3,849
April 19th, 2006 10:30 PM #6normally palit ka show sa honda sa pangalawang palit mo ng front pads. just have it cleaned nalang when papapalit ka ng front pads.
April 19th, 2006 10:39 PM #7
mas matagal ang palit ng brakeshoe, 2k gen1 crv ko lampas na 100k orig pa ang brakeshoe with no noise or stuck-ups pero lapit na rin un, front napalitan na once with oem Akebono non-asbestos pads.
April 19th, 2006 11:29 PM #8
depende nga iyan kung pwede pa ang brake shoe compare sa barke pad mo
better pa check mo na lang mechanic mo
alam na naman nila kung tatagal pa or hindi na
kung mejo madami ka budget at gipit ka sa panahon
(pra mag pa check uli) dahil busy ka lagi
palitan mo na pareho para isang gawaan na lang
Toyota is my choice
- Aug 2005
- 2,063
April 19th, 2006 11:34 PM #9Not really.. matagal ang shoe na kaysa pads.. check mo nlang kpag okey pa wag muna palitan.. =]
Toyota is my choice
- Aug 2005
- 2,063
Hybrids and EV
