mga Sir ok pa ba ang shock ko kase pag diniin ko sya walang ng pressure pero pag hinatak ko sya matigas . Corolla big body rear![]()
could be... but also look out for the other signs...
a) does your vehicle seem to bounce or slow to recover if you just came from a hump?
b) does your vehicle bounce up and down if you are going through rough roads?
c) on physical inspection of your shocks, do you see oil leaks?
if your answer is all of the above plus your statement above, it is a sign that your shock is busted.
actually ok naman ang ride ko, kaso lang may maingay kase pag nalulubak ako , eh check ko naman mga rubber bushing ko ok naman , baka kako ganon talaga shock absorber ko single action lang kaya ganon...
try checking din yung rubber beneath the spring baka sira kaya maingay ...
pero i think yung shocks mo na ang sira ... parang the way you describe it ... wala na siyang pressure ... mura naman yung shocks ng bigbody ngayon eh ... if kayaba yung shocks ... its about 1750 fluid type ... okay na yun ...
you can also check the shock mounting usually problem din yun ... check mo kung may crack na siya ... pero bihira naman pag likod eh ....
another reason is yung springs mo mahina na ...
check mo if your shocks have leak ...
BANAWE AUTO SUPPLY
regy
I'd would normally go checking the bushing first. A worn damper will usually have an oil leak (so merun ng tell tale signs). Now since matanda na rin ang big body, it doesn't hurt to replace it either...KYB brand might be very affordable for you.
