in choosing the correct tire pressure, it is said that we should follow what the manufacturer recommends.... is this an absolute truth? yung nakalagay sa driver's side door ng lancer mx is 2.1 kg/cm2. so around 21 psi? di ba masyadong mababa? what do you think guys?
I think you can follow but some people do it diffrent for me i follow like my light truck i only have 28psi considering almost 2 tons ang truck ko some times i put it until 25psi, but wait for the others kasi madaming me experience sa ganyan.
Follow the manufacturer's recommendation. But if I have no way of checking the pressure accurately (or close to accurate), my rule of thumb is: Don't let the tire look uneven (implies "don't let the sidewall touch the ground").
So kung medyo uneven (yung sobrang "dispormado" ang round shape ng gulong), dadalhin ko na sa vulcanizing shop or gas station for air refilling...
in my experience, for a typical sedan, 30 psi is kinda underinflated as shown by tire wear ... so i always add a little more, sometimes up to 35 psi
but tire wear depends on the car, your load, the tire, wheel alignment, etc ... and only after some 30,000 km that you'll see if the tire wear was even or not
I actually saw this first in another forum and there really is no need to put the chalk then run a quarter mile, i recall you can do this in your own garage as long as the tires are already warmed up and that you have a flat surface to roll the tires over. Summary of the different results should be something like this:
chalk wears out more on the shoulder = under inflated
chalk wears out more on the center = over inflated
chalk wears out evenly = proper tire pressure
On discussions i read about this method, the supposed proper tire pressure was reckoned to be about an average of 4 psi above the recommended psi on the label stated at the driver's side door jamb.
Sa experience ko ay okay lang ito (i.e. i'm using 36 psi instead of 32 psi as recommended) hanggang sa ngayon ay palaging pantay ang pudpod ng mga gulong sa mga sasakyan namin. added bonus ay slightly better ang gas mileage (i.e. subjective) and there is no noticeable sacrifice on the ride (i.e. again, subjective).
You may want to give this a try if it makes sense to you and judge the results for yourself.
Hope this helps.
