Page 1 of 2 12 LastLast
Results 1 to 20 of 37
    sabi ni Wolfpack na ang GT ay formulated for tropical conditions diba?
    I'm still debating whether I should keep my H/T and use the GT Savero as a 2nd set (if budget permits) when I get them eventually. BUT if kung hindi ko kaya mag 2 sets, mas mabilis pa rin ba mag-wear out ang Savero if it's my only set and I use my vehicle everyday?
    napapa-isip ako kasi kung formulated siya for tropical conditions BAKA hindi siya ganun kabilis mapudpod. hehe positive thinking... :D
    :beard:
    Mga more than 40K kms siguro kaya niyan. Ganyan gamit ng kabarkada ko sa Pajero nila, eh.
    SAVERO M/T na kunin mo. I'm eyeing them for my next set of tires. O kaya Maxxis Buckshot Mudders.
    on steel rims?
    ah oo nga, Savero M/T nga balak ko, sorry hindi ko nabanggit agad.tinatanong ko yung magka-pudpod ng Savero M/T's. kasi kung mabilis siya mapudpod, mas lalo na 1 lang sasakyan ko so I'll be using it everyday, try ko pilitin nalang na 2 sets ang tires ko...
    Olive,
    ako ba tinatanong mo about sa steel rims or si Otep?
    suggestion lang, better have two sets of tires. mud tires are great when new but when a little worn out they shake the vehicle a bit when you brake especially if IFS front suspension. they put much strain on the steering components. based on experince lang.
    keep your HT crawdad1
    Jan 2003
    I did not know that mud tires place more strain on the steering components. I know that large tires or heavy tires do add increased strain on one's steering but I never came across any data that claims that the tread design of a tire adds strain. I would think that mud tires (of the same dimensions as the stock tire) actually decreases direct strain to the steering since there is less contact area on the ground. Could someone please enlighten me if i am mistaken.
    Jul 2003
    Mud tires add more strain cause, they eventually go out of balance. habang nauubos at numinipis, sumasama ang balance nito.
    oteps,
    medyo magastos sa gas yang buckshot mudders. Bias ply iyan hindi radial ply. Mas mataas ang rolling resistance. mahihirapan ka din sa balancing niyan kasi after a while, out of balance na ulit. May supplier ba niyan dito?
    Steel belted na ba ang SAVERO M/T. Sorry, I can't afford two sets of tires...kailangan isa lang.
    i sugeest you get an agressive a/t tire na lang, like the BFG A/T KO. general grabber a/t. or you could try the simex centipede m/t
    wolvie - not all ha, based sa experience swamper, courser, but the new generation i dont know like the geo m/t, wrangler mtr. they make vibrations that you can feel all over the dashboard when you decelerate.
    ARB,
    I'm definitely going M/T's this time. Gusto ko sana yung BS M/T's ni KimpOy pero parang mahal (32" ang target size ko) so Savero, Maxxis or other off-brand tires ang choices ko.
    Hirap ang A/T sa bukid at sa lahar. hehehe.
    Otep,
    5,400 32'lang yata ang BS MT 673 sa blumentritt
    mag yokohama MTs ka na
    minsan may mga good 2nd hand pa dun kasi yung iba porma lang ang habol sa muds pero nung nalaman nila ride, trade nila ulit for ATs
    Wala bang nasa high 4k to 5K range lang?
    ungas got his 33s dunlop grantrek AT1s 2nd hand lang sa suking tire shop niya.
    ayos pa tires niya di ba?
    Sige, bahala na. Hehehe. Zero value na ata ang goma ko after Hi Peak. :p
    try mo BFG M/T KM series, the sidewalls are good looking. if you cant find one there we can always ship it from here like what wiretap_md did to his mags.
    ARB magkano size 31 niyan?
    yan ang hanap hanap ko noon
    Jan 2003
    I agree completely that mud tires tend to wear out faster and sometimes in an uneven manner. I also agree that they tend to vibrate or cause the steering to vibrate at times. I just wanted to point out that, while this might add unnecessary strain to the driver, it does not really strain your steering because your steering components are inherently passive and just respond to the feedback from the tires. It is only when you add your own inputs into the vehicle direction that the steering becomes an active component. this is how it was explained to me but maybe I am mistaken. The reason I said that tire/wheel dimensions and weight can affect or strain the steering (tie rod ends in particular and wheel bearings too) is because it is more a consequence of inertia and weight on the bearings and load on the tie rod ends. just my 2 cents.
    Bagay ba? hehehe.
Question About GT Savero Tires
